1978 - 1996 Big Bronco
over heating
Old Sep 21, 2004 | 04:20 PM
moritz1024's Avatar
moritz1024
over heating
i just put a 351w in my truck and put an electric fan in it instead of belt driven. and now the fan doesnt go on, and the temp. nor the electric oil pressure gauge works. now it over heats big time. can anyone help me?
Old Sep 21, 2004 | 04:50 PM
Kemicalburns's Avatar
Kemicalburns
hook up the electric fan so it works properly either by a toggle switch or a temp sensor. or go back to the stock setup which works . why did you go electric?
the oil gauge that isnt working would that be the stock one? if so then its either a loose wire or bad sender unit
Old Sep 21, 2004 | 04:56 PM
mswamper's Avatar
mswamper
Did you wire the fan on the same circuit as the gauges? If so, look for short or blown fues from too much load.
Old Sep 21, 2004 | 09:43 PM
BigBody's Avatar
BigBody
Get a F-250 Radiator. Thats what I have in mine and the gauge is always cool.
Kyle
Old Sep 21, 2004 | 09:44 PM
BigBody's Avatar
BigBody
Kyle
Old Sep 22, 2004 | 12:49 AM
greystreak92's Avatar
greystreak92
Ah yes the major drawback to electric fans...they need electricity. Chances are your gauge problem is a result of the overheating which could have fried the temp and pressure sensors in the block. Kemicalburns has a good question...why the swap? Check the archives on this forum in particular because the subject of just how effective electric fans are compared to the HP gains people look for by putting them in place of the stock fan has been beaten to death. As I recall the current draw from a fan or fans necessary to keep the truck cool creates nearly as much of an HP loss as the stock belt-driven fan.
RUBICON
2009 - 2014 F150
38
Nov 23, 2009 08:47 AM
powerstrokeddiesel
15
Aug 14, 2007 04:07 PM
3broncocrazy
Georgia Chapter
Jun 10, 2005 06:39 AM
munrow
Dec 3, 2004 02:53 PM
drewcoolness99
Sep 3, 2004 09:38 PM
