Bronco II Ford Bronco II
motor exchange
Old Oct 19, 2002 | 07:06 AM
cruisers4wdtoy's Avatar
cruisers4wdtoy
motor exchange
I will be putting a 2.9 motor from a 88 bronco II into a 86 bronco II will i be running into any problems any info will make this swap easy
Old Nov 22, 2002 | 12:27 PM
jan's Avatar
jan
motor exchange
Old Nov 23, 2002 | 08:37 PM
rebocardo's Avatar
rebocardo
motor exchange
Hardly any difference, though I believe in 88 the MAP sensor is different. If you are swapping harnesses and everything, it is a bolt up affair.
Old Nov 23, 2002 | 08:38 PM
rebocardo's Avatar
rebocardo
motor exchange
86 had a bigger throttle bore, put it on the 88 motor.
calzone
Bronco II
Apr 19, 2022 04:03 PM
86fordbronco_ii
Bronco II
Aug 18, 2014 07:12 PM
stuffman2003
Bronco II
May 17, 2006 08:17 PM
jimg
Bronco II
17
Mar 17, 2006 05:09 PM
Bronco II
Oct 16, 2003 12:49 AM
