Chassis lubrication
Old Sep 21, 2004 | 11:39 AM
mattmcl's Avatar
mattmcl
Chassis lubrication
The Ford Service book that came with the truck (99 XLT, 4 liter 4WD ORP, 5 spd) says to do the following:
Lubricate front half-shaft slip yoke
Lubricate transfer case shift linkage
Lubricate U-Joints
Chilton's adds the following:
Lubricate steering linkage
Chilton's says to do this with a grease gun at the grease fittings.
Here's the catch- Ford doesn't use zirks, so there are no grease fittings. What am I supposed to do, just slobber some grease on there with a brush?
Old Sep 21, 2004 | 12:52 PM
Mike W's Avatar
Mike W
When the parts wear out, the replacement ones should come with grease fittings.
Old Sep 22, 2004 | 07:16 AM
Phitty's Avatar
Phitty
What about a 2000 Mazda B4000, same issue - no zirks?
Thx.
P.
Old Sep 22, 2004 | 06:38 PM
maticuno's Avatar
maticuno
A grease needle might help to get into some of those tighter places.
Old Sep 22, 2004 | 06:44 PM
Redranger03's Avatar
Redranger03
Yep, that's the way I do it.
Best $3.00 tool investment you can make.
Old Sep 22, 2004 | 07:03 PM
Loan Ranger's Avatar
Loan Ranger
In the lubrication forum, be sure to read Rockledge's thread about both Molykote and its use by Ford on the slip joint on Ranger 4X4's!!
Old Sep 22, 2004 | 07:28 PM
maticuno's Avatar
maticuno
Where did you get a grease needle for only $3?
Old Sep 22, 2004 | 08:00 PM
racsan's Avatar
racsan
i just recently put new front axleshaft u-joint on my truck (the ones at the steering knuckles) and they didnt have grease zerks, not much room to get a gun in there anyhow, i do have a fully greaseable steering setup (except for the ball joints) i was also very surprized at the front wheel bearings, while plenty large enough, there aint but maybe 1/2 inch between the inner & outer bearings, hard to load the hub with grease when there is no room for any. my transfer case is a electric shift so i dont think there is anything i can lubricate.i did change the oil in it and the transmission last year. the other night i went to check the front axle oil level and had to use a hydraulic bottle jack against the wrench to loosen the plug. oil level was fine and what i could see of the differential looked clean. the rear differential will be harder to get a check on because its a recessed square drive (need something like a 3/8 drive extention to loosen it) the rear cover is made of some sort of nylon/plastic composite and id like to replace it, seen a real cool cover at rangerstation.com, may get something like that someday.
Old Sep 27, 2004 | 04:47 PM
Redranger03
Pep Boys...
Also the Kubota Dealer has them.
What are you paying??
Old Sep 27, 2004 | 04:53 PM
mattmcl's Avatar
mattmcl
I tried a needle valve kind that has a zerk on the bottom where it attached to the gun- worthless. I got more grease coming out around the needle than through it. That was the $3 one. Napa's the only one with a screw-on needle valve, going to give that a try tomorrow.
Old Sep 27, 2004 | 05:06 PM
Redranger03
I have no trouble with mine.
Old Nov 30, 2004 | 04:05 AM
jungle_expert's Avatar
jungle_expert
2000 ranger xlt 4x4
the front end is squeeking. can I install grease fittings or are there some factory installled?
Any help would be nice!!1
Old Nov 30, 2004 | 04:07 AM
jungle_expert
2000 ranger xlt 3.0 4x4
the front suspension is squeeking.
no grease fittings! what do i DO?
thanks
Old Nov 30, 2004 | 02:49 PM
Redranger03
jungle_expert,
I sent you a P.M.
Old Nov 30, 2004 | 07:00 PM
el conquistador's Avatar
el conquistador
ive seen some part that have plugs that you can remove and replace with grease fittings.
annaleigh
Dec 6, 2019 02:11 PM
RxCriticial
Apr 17, 2017 01:15 PM
TobaccoBarn460
Dec 12, 2015 10:10 AM
tip49
17
May 5, 2010 11:38 AM
Flooder305
1997 - 2003 F150
Oct 8, 2008 09:55 AM
