Got my build sheet!
Old Sep 20, 2004 | 08:22 PM
RyanMiller's Avatar
RyanMiller
Got my build sheet!
I got my build sheet from ford today, tell me if i have anything thats good or bad!
made in canada
hydraulic brake gvwr classe E 6001-7000lbs
f250 regular cab 4x4
5.0 efi v8 engine
1986 year
ontario assy plant
made 01 06 1986
133 " wheel base, styleside pickup
4 speed NP 435 tranny
3.55 limited slip rear axel
lt235/85r x x16 tires
bright areo head low mount 8x5 mirror
handling package
super cool radiator
heavy duty battery, heavy duty suspension, shaddow blue metallic, blue knit vinyl bench seat, tinted glass all around, mid body side wheel lip moulding package
thanks!
Old Sep 20, 2004 | 08:30 PM
1982fordf100's Avatar
1982fordf100
How do you get a build sheet? Do you give the VIN# to a dealer ship? Thanks Fred
Old Sep 20, 2004 | 09:15 PM
RyanMiller's Avatar
RyanMiller
gave ford a ring from the number on there website, and they gave me a few transfers and was on hold for a bit, then got a hold of somebody, gave em my VIN and address, and they send it up to your house for free, prety neat.
Old Sep 20, 2004 | 10:47 PM
Beast12's Avatar
Beast12
I did the same thing. I posted it in this forum somewhere. EDIT: Here's the link: https://www.ford-trucks.com/forums/s...ghlight=sheet+ Anyway, I just went to Ford's website and emailed them.
-Matt
Old Sep 21, 2004 | 08:11 AM
82F1507.5's Avatar
82F1507.5
Difficult to say
Assuming nothing has been changed from the original build, you have one tough well made truck that should last many more years along with diligent maintenance. It is not as powerful as a 351, but is not as thirsty either. It will do most any task you can ask of a 3/4 ton truck as long as you don't try to trailer another 3/4 ton truck behind it. It will do that too, but the brakes are not quite up to the task unless you have electric trailer brakes. The 3.55 limited slip gear set is probably the best universal gear set for that truck, engine, and transmission combination. What you have is a "real" truck, it is not a "car-truck" or a wimpy hauler, you should be very happy with it!
Old Sep 21, 2004 | 11:34 AM
andym's Avatar
andym
I hope the tranny's right. I ordered a build sheet for my old '86 Bronco, and they had the wrong tranny listed. It had an NP435, but the sheet said Warner 4 speed. I know it wasn't swapped, because the door post sticker was correct.
Old Sep 21, 2004 | 10:54 PM
MontanaFord's Avatar
MontanaFord
i believe the np435 is just the transfer case, not the transmission...don't take my word for it, though...
MontanaFord
Old Sep 22, 2004 | 01:20 AM
big hoss 29's Avatar
big hoss 29
The NP435 IS the tranny. It's a great unit to have under your truck.
Old Sep 22, 2004 | 06:18 AM
82F100SWB's Avatar
82F100SWB
Ah, a F250 light duty, more capacity than a f150, without the weight penalties of the HD frame and full floating rear end, but, also without the big rear brakes.
MontanaFord: You're confusing the 435(which is a transmission) with the 203, 205, and 208, which are transfer cases.
Old Sep 22, 2004 | 09:08 AM
locknkey's Avatar
locknkey
Normally, the build sheets are attached to the underside of the fuel tank anyway, unless its been removed somewhere down the road...at least mine were still on the 77 Ford when I dropped the tank last year to remove the water out of it, very interesting information about the building of it...have done the same thing to my old Monti Carlo years ago and it was also on top of the fuel tank, don't know if all autos are like that...but assume they are....or stuck on the back seat between the frame and top seat.(seen them there too when I was younger junking out autos)
akorcovelos
Jan 27, 2011 01:19 PM
mq1shooter
25
Nov 13, 2010 05:43 PM
Smurf-Slayer
Sep 29, 2004 01:45 PM
96-5spd302
Sep 13, 2004 02:37 PM
