Bronco II Ford Bronco II
86 , 2.9 Overheating
Old Dec 22, 2002 | 01:50 PM
jan's Avatar
jan
Tried pressure test, will not hold pressure but I can't find a leak. Tried block tested, came out AOK. Losing fluid but absoutly no leakage. Where is the fluid going ?? When it overheats it comes back through the resevior. HELP !!!!
Old Dec 23, 2002 | 03:25 PM
tolvibman's Avatar
tolvibman
Did you look at the weep hole at the bottom of the waterpump shaft seal? Some years back had a buddy with a BII who thought he had a cracked head/block because he was mysteriously loosing coolant. Turned out to be a bad mechanical seal in the water pump that would only leak when the truck was running and hot. Hope this helps.
Old Dec 23, 2002 | 06:50 PM
jan's Avatar
jan
Thanks, I'll give it a go.
Old Dec 24, 2002 | 12:40 AM
89BroncoII's Avatar
89BroncoII
4dfan
General Automotive Discussion
Dec 13, 2013 12:07 PM
rock2610d
Modular V8 (4.6L, 5.4L)
Mar 18, 2013 07:44 AM
lavatan
May 9, 2012 12:01 PM
House Husband
Aug 12, 2008 06:17 PM
FAB150
Mar 28, 2006 12:33 PM
