Not sure if this goes here so please move it if you need to.
I am looking for any information about the 03 and new Ford Transmission Cooler lines. I have an 03 SD with an automatic and I want to have a tool to remove that line.
I purchased a plastic tool from Matco but it broke as soon as I used it.
Does anyone have any other tools, the box says Similar to Ford No. 307-459
the ford tool is made by rotunda. 307-459. check the web for a phone number or see your local ford dealers service manager and have him order you one. it should be small and white and clip together around the line. as little as it is its hard to believe it works, but it does
