1978 - 1996 Big Bronco
Something wierd
Old Sep 19, 2004 | 10:07 PM
serverguru's Avatar
serverguru
Exclamation Something wierd
Today I was backing my brocno up and something was brought to my attention.
If you are looking at the Bronco from the front and watch it back up the front tires start to bow in and makes it look like this.
When you pull forward it looks like it should, Like this
This is really wierd.
Any Ideas?
Thanks,
ServerGuru
Old Sep 19, 2004 | 10:42 PM
greystreak92's Avatar
greystreak92
Like this \ / really? That is actually pretty good. If its like this / \ then you are dealing with possible balljoint problems. But the other way merely means the toque is letting the front ride up a bit on the suspension as you back up. Truthfully, its probably not a problem. When backing the alignment areas are put through a completely different sert of stresses and pressures and as long as it comes back when you pull forward, you should have no real problems.
Old Sep 20, 2004 | 07:49 PM
BOJOFASO's Avatar
BOJOFASO
mine does the same thing but definately not as bad as your picture shows.
Old Sep 21, 2004 | 09:02 PM
serverguru's Avatar
serverguru
I took it in and had an alignment done today. It fixed that problem. Now on to the next one what ever it is.
Thanks for the advise.
ServerGuru
housetruck
Oct 4, 2016 12:54 PM
lawdawg79
Dec 10, 2015 02:35 PM
fordfarmer12
Mar 6, 2012 09:36 AM
jeddy53824
Aug 17, 2006 03:34 PM
newexpy
Sep 26, 2003 09:07 PM
