Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2004 Tribute/Escape 6 CD Changer Problem
Old Sep 19, 2004 | 04:55 PM
Pallor's Avatar
Pallor
Red face 2004 Tribute/Escape 6 CD Changer Problem
Greetings!
I know this is a Ford forum, but I thought I would ask about my 2004 Mazda Tribute since they seem to be very similar.
Today, my in dash 6 disc CD changer in my 10 month old Tribute has decided to eternally be stuck on "eject". Much to my dismay, I cannot get it to do anything else. I have read the manual and it was not overheating, had not been offroading (not being jarred), etc.
I live an hour from the closest Mazda/Ford place (which has a Mazda mechanic every 4th week). I wanted to know if others have experienced a similar issue with this cd system. I may have to consider replacing the one included in the beefed up audio package if this is a common issue.
Thanks!
-- Meg
Old Sep 19, 2004 | 07:55 PM
yysenhimer's Avatar
yysenhimer
Make sure the button isn't stuck. I know on my wife's Escape sometimes a few of the buttons can get stuck. When you push it in it doesn't pop back out. Just mess around with it first.
Old Sep 19, 2004 | 08:01 PM
Pallor's Avatar
Pallor
Wink
Thank you for the reply.
I tried for about 30 minutes to get the CD player to do anything. The button most likely is not stuck. I originally attempted to switch discs internally and the disc changer started to click and not retrieve the disc. Thus, I pushed the eject button attempting to see if changing tasks would reorient the system. Sadly, the system is now stuck on eternal "eject" rather than eternal attempts at switching the disc. I turned off the SUV and restarted it, thinking that perhaps a reloading of the audio system would fix the issue. It did not.
-- Meg
Old Sep 19, 2004 | 08:11 PM
bananaboat's Avatar
bananaboat
I don't have an answer but hang around. Mechanically speaking, the Tribute/Escape are the same vehicle.
Old Sep 19, 2004 | 08:43 PM
Racerguy's Avatar
Racerguy
I've sent out a few 6-pack CD players for repair. They do seem to be somewhat unreliable.
If you don't mind something that doesn't look stock you could get an aftermarket stereo that will probably work and sound better and last longer. It would probably just be a single CD though. If you are into such things, a player that plays MP3s is nice too
Old Sep 20, 2004 | 07:18 AM
yysenhimer's Avatar
yysenhimer
Maybe try disconnecting the battery for a few minutes? Sometimes that does the trick with electronics that are messed up.
Old Nov 16, 2004 | 06:41 PM
kdevious's Avatar
kdevious
Hey Meg -
Don't know if you found your fix for this, but I have a couple answers. I had an '02 Escape with the Mach Audio changer in it and now have the '05. On the first one I constantly had CD's get stuck when trying to eject them. The first real bad times, when I couldn't get the CD's out, I brought it into Ford. They took the stereo out - sent it for service and a couple of weeks later put it back. The problem never went away.
So here's what I did...
1. Never play any homemade CD's with the paper sticker on it. If you burn a CD, just write on it for the Escape.
2. If a CD does get stuck in there, keep something like a credit card, a hotel room card, etc. in the car. When the CD is caught ejecting, you can see it in the doorway. Just slide the card in above the CD, inside the slit of the player. It will release (99% of the time).
Hope that helps!
- K
Old Nov 17, 2004 | 05:59 PM
splashtm's Avatar
splashtm
If you wanna wait a few weeks, my 05 Tribbie will arrive, and you can have the upgraded deck I'll be removing immediately upon arrival.... I hate disk changers, and had no choice, so i want it gone.
Old Nov 17, 2004 | 06:57 PM
Pallor's Avatar
Pallor
Thanks for all the input guys. I appreciate it.
Sadly, today I just got the deck replaced. Its been over two months. I was originally told 7 days. It was backordered. That should at least indicate this may be a decent problem.
Interestingly enough, the six discs stuck in the deck were not removed. I was told Mazda central will have to receive the deck and then remove the discs. They will be sent back to the dealership, who will then send the discs to me. I figure I'll get my discs back sometime in February. It was unclear whether the dealership was unable to remove them, or if removal would further corrupt the system, or if the whole system has to be shipped back for Mazda inspection untouched.
So thus ends my story over my deck.
Splashtm: Is the 2005 deck any different than the 2004?
Cheers and thanks!
-- Meg
Old Nov 19, 2004 | 04:48 PM
splashtm's Avatar
splashtm
I don't think they changed the deck for 05. Most likely the same POS you've had problems with. It's the upgraded stereo, for what it's worth. I've never even been inside an 04. I just thought I'd offer. Some folks really like to have factory, and they cost a first-born when purchased through the dealer.
Green96
Dec 27, 2013 12:25 PM
DJR96
13
Dec 7, 2012 05:59 PM
Grahams
Jul 25, 2010 09:48 PM
jzlvr1
Sep 10, 2007 06:40 PM
