I don't know about your truck but lots of older vehicles use vacuum to operate the air doors. In the event that the vacuum source is lost, the doors would fail to the defrost position so you could at least still drive.
If your truck works like this you will have a vacuum line going into the firewall. Check for vacuum there, and maybe use a vacuum pump to apply vacuum.
I think I isolated the problem. THe vacuum pump is running nonstop. The tube comes out of the pump and then goes into an oblong plastic box about the size of a nerf football. That seems to be where a leak is.
Do you know what this box is? It is right behind the battert (2 batteries on this truck)
It may be an accumulator. Especially if it only has one line going to it. Think of it as a large volume of vacuum that is stored up. If you didn't have it you could only store up as much as the lines could hold.
Try to clamp the line that goes to the accumulator, them see if the the defrost problem straightens up. If it does, replace the accumulator.
As far as the vacuum pump running continuously, I think that's normal.
i have this same problem. my a/c works fine all the time except when i put it in 4wd. then the a/c defaults to defrost. the 4wd does not work unless you manually turn the hubs. the a/c quits whether the hubs are manually locked or not. i have no idea where the leak is though. the engine is much noisier than any vacuum leak. any tips on how to find the leak?
thanks, steven
