Bronco II Ford Bronco II
XMSN Shift Problems
Old Jan 11, 2003 | 12:26 PM
Bronco2guy's Avatar
Bronco2guy
XMSN Shift Problems
Old Jan 11, 2003 | 02:50 PM
rhrandyh's Avatar
rhrandyh
Post XMSN Shift Problems
I have 90 II 4wd that recently has started to shift late. It does not go into 2nd until about 3800 rpms. All other shifts are about the same. Any Ideas?
Old Jan 12, 2003 | 11:42 AM
Bronco2guy's Avatar
Bronco2guy
XMSN Shift Problems
Your problem is that the automatic transmission that your truck has is not very good. I would suggest servicing it and flushing the fluid and if that doesn't help it is going to have to either be rebuilt or replaced. sorry to be the bearer of bad news.
Old Jan 19, 2003 | 06:29 PM
rhrandyh's Avatar
rhrandyh
XMSN Shift Problems
Thanks for the help--thru further research I determined it was the xmsn vacuum modulator. It runs good now. Also the modulator valve is very difficult to get to.
