Bronco II Ford Bronco II
cb
Old Jan 19, 2003 | 03:47 PM
JEEPKILLA87's Avatar
JEEPKILLA87
cb
if amybody knows how to install a cb radio please relpy and also if you have pics please put them on here or email me at dovehunter@nc.rr.com
Old Jan 19, 2003 | 05:30 PM
SplashMan's Avatar
SplashMan
cb
There are two ways to install... the first and easiest is to get a cigarette adapter from Radio Shack. The other (better) way is to just run the red wire(power) to a unused fuse block or directly to the battery and then find a nice place on the firewall or under the dash to attach the black(ground) wire to.
Old Jan 20, 2003 | 08:39 AM
JEEPKILLA87
cb
also if ykou have any pictures of the wiring that would help alot
Old Jan 20, 2003 | 11:41 AM
SplashMan's Avatar
SplashMan
cb
I don't have any pics of the wiring, but what I did was run the wire through the hole in the firewall for the throttle cable. then I ran it along the back of the engine compartment and then up the left side to the battery. I hooked the positive and the negative to the battery and then just zip tied all of the wires out of the way of any moving or hot parts.
