carb question?
Old Sep 19, 2004 | 10:29 AM
drew222's Avatar
drew222
carb question?
I put a new Edelbrock performer 500cfm carb and intake on my '74 302. A month later, I ran out of gas, and it now sputters at lower r.p.m. and then evens out. I dis-assembled the ENTIRE carb, cleaned it ( no signs of dirt), and put a new fuel filter on. The problem is still there. What am I missing? I don't know how old the fuel pump is and not sure if it could be something else, but the engine ran great before I ran out of gas. How about some input, Thanks
Old Sep 19, 2004 | 10:45 AM
1081's Avatar
1081
This could be a tricky one, I can't think of anything running out of gas would change unless it effected a diaphram or seal. You might double check the seal around the accelerator pump as well and maybe pull the plugs and see if one fouled along the way. (Just some thoughts).
Old Sep 23, 2004 | 09:53 PM
Big ole Dog's Avatar
Big ole Dog
Is the pump in the tank? The fuel that surounds the pump also keeps it cool so if one keeps the tank atleast 1/4 full the the pump should run cooler and a cool pump is a happy pump
The probley does not help you but they are just my thoughts
Mikesjusmc
Nov 17, 2013 08:29 AM
XbrandonleighX
Jun 10, 2012 01:45 PM
BossFan
19
Aug 20, 2011 06:59 PM
sneakys44
Apr 4, 2004 09:56 AM
78bigunns
18
Aug 19, 2003 01:53 PM
