Adding A/C
Old Sep 18, 2004 | 05:16 PM
Tottspop's Avatar
Tottspop
Adding A/C
I have a 47' 1/2 ton and I would like to add A/C and heat so I don't melt driving it. I have no idea where to look for an after market system. My goal is to make it look as it was a factory instalation in the cab.
Melting in Vegas
Old Sep 18, 2004 | 08:07 PM
Bikeitswift's Avatar
Bikeitswift
What motor are you running? Are you 12 or 6 volt? The hot rod sites will show plenty of solutiions. I put a system in my stock 63 F100 with a 223 inline six that came out pretty good. I basically replaced the stock heater unit with an AC/Heat unit from Hot Rod Air that went in the same spot , all you saw afetrwards were the air ducts under the das and the small control panel. I fabbed up my own engine brackets from a kit for a Chevy 6 and it all worked great! (South Texas). Got some pics if interested.
Old Sep 19, 2004 | 03:12 PM
46fordtruck's Avatar
46fordtruck
Well, adding A/C to make it look factory in a '47 is a tough one. You can use an art deco style vent, I've even seen '36 Ford horn covers used as the covers for A/C registers. Check out rod magazines especially Street Rodder for ads of places that carry A/C systems. Vintage Air in TX is good, and so is Southern Air. They will be able to supply you w/ the underdash units, and all the stuff, including a new A/C ready radiator.
first today
Jan 26, 2013 08:52 AM
Fab
Aug 19, 2012 08:57 AM
jeronlines
Nov 29, 2010 04:22 PM
jippy
1983 - 2012 Ranger & B-Series
Mar 21, 2010 09:21 AM
twisted
1978 - 1996 Big Bronco
May 21, 2005 02:25 PM
