<TABLE align=center><TBODY><TR><TD>Flip a switch to bypass your muffler for a quick burst of additional horsepower. The ceramic coated stainless steel Power Master provides in cockpit bypass control of exhaust gases when maximum torque and horsepower is needed. This device eliminates the need for full exhaust system replacement when using performance enhancing chips on Ford Power Stroke Diesels. Dyno proven to increase torque / horsepower and reducing exhaust gas temperature vs stock and 4" aftermarket systems.
Darn good looking setup. Since I am a mechanically challenged person, where do you get it and who would hook it up? Would some mechanic tell me it is illegal and not install it?
That is a pretty trick exhaust upgrade. I've seen similar products that work from a cable attached, but this is the first electric/push button version. Thanks for sharing.
