Greasing upper ball joint
Old Oct 6, 2010 | 04:52 PM
hammer65's Avatar
hammer65
Anyone using one of these on the upper ball joint with a straight grease nipple? Jim
Lincoln Lubrication (LIN5883)
Slotted Right Angle (90 Degree) Coupler
<table> <tbody><tr> <td id="ttProductImageColumn">
</td> <td id="ttProductDetailsColumn"> <table> <tbody><tr> <td colspan="2"> </td> </tr> <tr> <td class="key">List Price</td> <td class="value">$9.07</td> </tr> <tr> <td class="key">Your Price</td> <td class="value price">$5.27</td> </tr> <tr> <td class="key">Item Number</td> <td class="value">LIN5883</td> </tr> <tr> <td class="key">Mfg</td> <td class="value">Lincoln Lubrication</td> </tr> <tr> <td class="key">Part No</td> <td class="value">5883</td> </tr> <tr> <td>
</td><td class="key addToCart"> <label for="ctl00_pageContent_txtQuantity" class="label"></label><input name="ctl00$pageContent$txtQuantity" value="1" maxlength="10" size="3" id="ctl00_pageContent_txtQuantity" class="textbox-center" type="text"><input name="ctl00$pageContent$addToCart" id="ctl00_pageContent_addToCart" class="prod-detail-add" src="http://www.tooltopia.com/themes/migration-1-1/images/buttons/cart_btn_add.gif" style="border-width: 0px;" type="image">
* Whole number only
</td><td class="key promo"> In stock: Yes </td> </tr> <tr> </tr></tbody></table>
</td></tr></tbody></table>
Old Oct 6, 2010 | 07:21 PM
vans's Avatar
vans
I have one, I went with the straight zerk because I was worried about clearance with the 90 degree and u-joint
FYI- you will have to engage your front end to rotate u-joint to gain clearance, knuckle is usually in the way
Old Oct 6, 2010 | 07:48 PM
big poppa's Avatar
big poppa
Couldn't even install a zerk in mine up top, same problem, clearances. Very nice adapter though.
Old Oct 6, 2010 | 08:24 PM
hammer65's Avatar
hammer65
Thanks Guy's:
Old Oct 6, 2010 | 09:12 PM
frdf250's Avatar
frdf250
is there a way to take that little bolt out on the bottom of the ball joint if it dosent have a grease fitting on it and put one in? there not bad so i dont want to replace them, but jsut want to prolong it
Old Oct 6, 2010 | 09:28 PM
novice psd's Avatar
novice psd
Yes you can, I installed 90 degree ones in the top ball joints. The clearance is close but it will fit, been in mine a couple of years no problems.
Old Oct 6, 2010 | 09:34 PM
frdf250's Avatar
frdf250
that is so cool, do you know what size that is?
Old Oct 7, 2010 | 07:27 PM
novice psd's Avatar
novice psd
The ones I used are 1/4"X28 90degree, I don't remember whether they came from Auto Zone or O'Reilly's. They are aggravating to install but work fine.
Old Oct 7, 2010 | 07:30 PM
twags6's Avatar
twags6
Not all the trucks clear the fitting. Mine would rub and I know Kris snapped one of his off while in 4x4 even though it cleared the joint normally. Test it out before you go driving.
Old Oct 7, 2010 | 08:41 PM
milleroutdoors's Avatar
milleroutdoors
Mine did not clear, I pull the plug, install a fitting, grease, then remove and reinstall the plug. Kind of a pain but I have yet to find a zerk that clears.
Old Oct 8, 2010 | 10:48 AM
twags6's Avatar
twags6
Would a straight zerk clear? Thats what some of the guys are doing and they use the adapter pictured at the top of the thread. No need to permanently hook it to the grease gun either. Just thread a grease fitting into the end of the adapter and pop it on the gun when you need to do those fittings.
Old Oct 8, 2010 | 12:16 PM
jgilrfr's Avatar
jgilrfr
I use a straight zerk and the fitting originally listed I had to grind the back side of the fitting a little to fit(and you can grind it too much),I am thinking of grinding the zerk a little too because it is still a tight fit.
Old Oct 8, 2010 | 02:27 PM
milleroutdoors
None I have will clear, I am sure I will find one eventually.
Old Oct 8, 2010 | 05:34 PM
SteveH-CO's Avatar
SteveH-CO
A straight zerk clears easily on my '01. I use the pictured adapter. I just found some old SAE zerks in a drawer - nothing fancy or Metric.
But - don't get the adapter (made in China) sold at Pep Boys - it did not work at all. I got one at NAPA and it works well. The NAPA one fits VERY tightly (as it must) and seals well. The Pep Boys version had softer plastic in it, and leaked grease profusely and never allowed grease into the joint.
Old Oct 8, 2010 | 07:17 PM
big poppa's Avatar
big poppa
General concensus suggest that most ball joint failures are the lower ball joints, from what I've seen over the years so I make sure my lowers are grease every oil change, sometimes even more depending.
