speed density sensor location?
Old Sep 18, 2004 | 02:26 AM
coplin's Avatar
coplin
Red face speed density sensor location?
Is the speed density sensor attached to the underside of the hood? If not what is that thing then? Its definately not an underhood light.
Old Sep 18, 2004 | 07:09 AM
MustangGT221's Avatar
MustangGT221
Um...never heard of a speed density sensor
Old Sep 18, 2004 | 10:40 AM
faroffthetrack's Avatar
faroffthetrack
You may be refering to the Manifold Absolute Pressure (MAP) sensor.
Old Sep 18, 2004 | 10:47 AM
GST97's Avatar
GST97
I had wondered what that thing attached to the hood is also. I should find the wire colors and look in my manual as to what it connects to.
The MAP sensor (at least in my truck) is on the passenger side near the firewall. It has a vaccuum line attached to it and a 3 wire plug. Can't miss it
-Chris
Old Sep 18, 2004 | 04:10 PM
EPNCSU2006's Avatar
EPNCSU2006
The only thing on my hood is the light - green wire and a black wire.
Old Sep 18, 2004 | 05:54 PM
BigBlue 92's Avatar
BigBlue 92
speed density is a system, not a sensor. there are speed density and mass airflow systems. speed density systems rely on many sensors on the engine, drivetrain, etc. to provide information to the computer so it can calculete the advance curve and injector duty cycle. speed density systems have a preprogrammed fuel curve that doesnt change, so different mods that increase/deacrease airflow will make the engine run lean or rich. this due to the fact that speed density systems dont measure airflow directly. Mass airflow systems however do not require as many sensors to run the engine and have a flexible fuel curve because they directly measure how much air the engine is pulling through it. it is a good idea to change to a mass air system if you plan to do any mods, but the speed density system does a good job running a stock motor.
Old Sep 18, 2004 | 05:55 PM
faroffthetrack
Cant you get a picture of it? The only thing under my hood is the light.
Old Sep 18, 2004 | 06:01 PM
EPNCSU2006's Avatar
EPNCSU2006
The programmed fuel curves don't change with MAF either - the computer just references them based on air mass rather than from MAP readings, so it is able to adapt to airflow changes better. The MAF system uses all the same sensors as the SD system does, just adds the MAF meter.
Old Sep 18, 2004 | 07:59 PM
coplin's Avatar
coplin
gotta lay off the C.C. for a while
Seems that the thing under the hood IS a light. It resembles a light even better when there is a light bulb in it
With that light bulb in the socket now, the truck should be able to sense its speed alot better now eh?
The reason it threw me off is no bulb was in it(new to me truck). And on GM's the light bulb and mercury switch are a single unit. Ford's are obviously a two piece deal. Woops!
Old Sep 18, 2004 | 08:59 PM
MustangGT221
That socket is your mercury switch also...
Old Sep 18, 2004 | 10:22 PM
coplin's Avatar
coplin
Fine then, shred the last little bit of my dignity.
Old Sep 19, 2004 | 02:45 PM
faroffthetrack
LOL It's alright we've all made plenty worse mistakes.
Old Sep 19, 2004 | 03:03 PM
MustangGT221
It's what moderators are for
haha jk
Kirbys73F100
13
Dec 17, 2025 11:40 AM
gastelumri
Escape & Escape Hybrid
Sep 24, 2015 05:37 PM
Sixtone
Mar 19, 2015 05:26 PM
AJUSAcom
Vendor Specials, Discounts, Product Announcements & Group Buys
May 4, 2012 05:46 PM
dunnc1989
Mar 6, 2011 07:10 PM
