hego sensors
Old 03-06-2011, 07:11 AM
dunnc1989
dunnc1989 is offline
dunnc1989 is starting off with a positive reputation.
hego sensors
did a swap from speed density 300 to maf 302. isnt the 302 supposed to have 2 hego sensors? if so what colors are the wires for left bank and where might i be able to find the plug?
Old 03-06-2011, 07:30 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
EPNCSU2006 has a great reputation on FTE.EPNCSU2006 has a great reputation on FTE.EPNCSU2006 has a great reputation on FTE.EPNCSU2006 has a great reputation on FTE.
If you used a mustang computer, yes it has two O2 sensor inputs. If it was a truck MAF computer, it only has one input. Have you checked for trouble codes, or are you getting a check engine light? If it's looking for an O2 sensor that isn't there, you will have a code for it.
Old 03-06-2011, 12:50 PM
dunnc1989
I used a truck computer and harness. although i used the wrong computer(has auto trans controller). so i bought a new one for a stick shift and just trying to get the bugs worked out. it runs rough which is why i ask, sounds like it has a miss.
Old 03-06-2011, 05:53 PM
EPNCSU2006's Avatar
EPNCSU2006
What did the 302 come from? Double check the firing order and make sure the plug wires are connected the same. Pull codes from the computer and see what comes up.
Follow the procedure here, but leave out the volt meter and watch the check engine light (if it works): EEC IV Self Test hookup
Old 03-06-2011, 07:10 PM
dunnc1989
figured it out, cylinder 1 injector was unplugged from the harness. Plugged it in and now she runs great other than the stutter under load sometimes, but i attribute that to the computer thinking there is a trans behind it that isnt.
rcarson25
01-17-2016 12:53 PM
rustee90-150
24
11-16-2011 08:05 AM
SideWinder4.9l
07-30-2011 08:29 PM
FourXFord2
1978 - 1996 Big Bronco
15
03-02-2011 11:36 PM
nnewman
05-15-2009 01:44 PM
Quick Reply: hego sensors
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
