How much would it cost to go out and get my 94 F150 wired up so that I could have keyless entry on it?
Also...would it be possible to get remote start on it? It'd have to be rigged somehow so that if in gear it would balk at the order. Otherwise most go until the engine starts in which case if I hit it while the truck was in gear it'd make the truck lurch and lurch till it finally started and drove off by itself in gear into who knows what. Eh..if they can't disable it starting in gear, maybe I'd stick with it just being able to have keyless entry. Thanks!
i have seen a kit for manual trans trucks before it comes with a neutral safety switch that way if it is in gear it wont start.these kits normaly run between 300.00 and 500.00 it just depends on where you buy it
