Environment license plates
didn't mean to spank you
And I don't get the "I burn cooking oil so I don't pollute" bit either. What is cooking oil? Cooking oil is a lipid. What's a lipid? Fatty acids and glycerol. And what is a fatty acid? A bunch of hydrocarbon chains. You're still burning hydrocarbons, then you're still polluting.
No, I'm just saying that both engines pollute in different ways. You probably know more about this than I do anyways.
Bottom line is:if you don't want to pollute, buy an electric car.
electric cars
Seems to me the "big picture" has been lost in this battle. The continued focus on autos with new standards every year is counterproductive. How close to zero can you get?
Meanwhile, the increased cost of cars slows the turnover in the fleet. And if you want to clean up cars, nothing would do it like everyone driving an '05 right now.
Now all you fellas with the '64 F-100's cleaning out the road draft tube on your 292 needn't worry. Not enough to make a big difference. It's the '93 pot-metal motor'd Mitsubishi pumping oil and the fleets of BMW 320i's running around with dead cats doing the damage. It's the last of the carbureted units running around with stuck chokes. It's the millions of Crown Vics with 200,000 cop and taxi miles doing double duty as transportation and mosquito control.
I read a fellow's calculations a few years back about electric cars when the that GM rolling toaster came out. If you do some figure work on the whole project, it turns out that you could, for less money, go into the poor part of town where the rolling totals foul the air, and trade them new Caddys (or Lincolns, I suppose) for less money.
Anyway, gotta go work on my new 3 car garage so I'll have some place to work on the carb on my van & keep my 2 stroke dirt bike.
Here in CA (probably other states as well) the politicos have a bad habit of robbing from enviro funds to help balance our bloated state budget, so the enviro plate money doesn't make it to the intended agencies.
Steve
http://www.distributiondrive.com/Article16.html
It may not be perfect, but it sure is the best thing going right now. Better than electric or hydrogen (unless you go nuclear-whoe other subject).
One of us must not understand the hydrocarbon issue very well I'll give you my interpretation and you tell me if I'm wrong:
You said: "And I don't get the "I burn cooking oil so I don't pollute" bit either. What is cooking oil? Cooking oil is a lipid. What's a lipid? Fatty acids and glycerol. And what is a fatty acid? A bunch of hydrocarbon chains. You're still burning hydrocarbons, then you're still polluting."
I though it was UNBURNED hydrocarbons that were the problem. Seeing as how diesels are already lower in these, and biodiesel (according to EPA tests-I've seen better) has a further 67% reduction, it seems it deserves a little more credit than you give it.
SOx sucks! ) among others to contend with. Here's another problem with biodiesel; it puts out more NOx than regular diesel, some sources say as much 37% more for B100. Both HC and NOx are a part of the problem but NOx is what makes ground level ozone according to the EPA. Ground level ozone is our biggest air-quality problem in the DFW area. I've been looking at several web sites (gov't and state) to see what the various emission standards are but I haven't been able to get coherent data from that. Also, it's impossible to find specific info on different engines. Grams per Mile will differ by engine size and type let alone by year of manufacture.
However, I found some European sites that have a little clearer information. The information points to the fact that for example, Euro II (1998) gasoline emission standards allow 0.57 grams per Kilometers of NOx and HC combined while the Euro II standard for diesel is 0.70 g/km. What percentage of this HC+NOx is HC? As far as I can tell, 9.3% of the .70 figure is comprised of HC for diesels and 30% of the .57 figure for gasoline for that particular table. In another table, I see also that CO emissions for gasoline are double that of diesel. Allowable NOx emissions are 69% higher in diesels than in gasoline. Allowable HC emissions are 70% higher in gasoline engines than diesel engines. So we can assertain that gasoline engines pollutes mostly by HC's and diesel engines pollute mostly by NOx but a diesel engine is allowed to put out 18.6% more emissions than a gasoline engine. (Neither the EPA nor the TCEQ/TNRCC had any info that I could find on this matter.)
What I need to do here is find someone with a 2003 6.0L diesel. Then take my 2003 5.4L gas and the 2003 6.0L diesel to a smog inspection station and see what the results are for HC and NOx for each engine. This would be the only way to tell for certain what we have here. This is difficult at the moment because all my friends have 7.3L diesels. No one has traded their trucks in yet. And still, the results won't be completly meaningful because of the Cu. In. difference, pollution control devices used, and the method of fuel injection.
Now, don't get me wrong, I think biodiesel is a great idea but I can't give it any credit myself because I can't use it. I would rather put money in the pockets of American agri-business instead of Middle-Eastern oil men who hate our guts.
A few reasons come to mind as to why cat converters were not required earlier. Diesels have been available in consumer vehicles only since 1982 (6.2L GM diesel, unless you count the rare diesels in the 1978 Dodge Power Wagon.) These vehicles were mostly of the 8500 GVWR and above size which has had much laxer emission standards. Just recently are these standards including diesels. Yes, true, there were the odd europen cars here and there but not enough to redefine the rules. (my guess) Also, according to an article I found, diesels including heavy trucks still only make up 1/4 of all vehicles in use in the US. There is a much greater number of gassers out there, hence the cat requirements.
NOx is pretty easy to get back to regular diesel standards by retarding inj. timing a couple degrees. This would need to be done w/ any diesel fuel w/ the cetane #'s biodiesel provides. This is the part where I agree w/ you
: The problem is that diesel engines give off 8+ times more NOx than gasoline from the start (as far as untreated exhaust goes). Besides the Catalysts they have devised to treat this problem(though not in use yet, in the states, due lack of urea distribution), there isn't much that can be done. The reason the other emmisions are so low is because the extreme heat the fuel is burned at and the length it is exposed to this heat is the same thing that creates NOx. the cats present on todays diesels can only do so much about this.Urea (harmless) will transform seperate NOx into nitrogen and oxygen and does it very well. the con w/ this is you need to replenish the urea like you would fuel (not too big of a problem, considering the benefits). Mercedes is set to have just such a system here soon (2006-2007). The Great thing about biodiesel is that once you get this small hurdle cleared, you are well on your way to a zero emissions vehicle (with use of catalytic converters of course) once warmed-up(cold start output will still be a problem-minor in comparison though). Zero meaning no dirtier than the air that came into the engine
. Gasoline (compared to biodiesel) has many more compounds in it that pass through the cat unchanged from my understanding. This doesn't even touch the evaporative qualities. SOx is completely eliminated w/ biodiesel (it contains no sulfur).PM is reduced, usually, by over 90% almost eliminating it/them (once you factor in particulate traps which will be set in place for regular diesel-they will be)Does anyone have any info regarding the differences between gas and diesel cats? (as if anyone's read this far)
Man, your right, it sure is hard to find any concrete #'s regarding this subject. I looked and looked. I was under the impression that the ULEV standards for gas and diesel in the states was the same (I could very well be wrong here). Also there may or may not be a different ULEV standard for "medium duty" vehicles. heres one thing I did find:
California LEV II Emission Standards for Passenger Cars and Light Duty Vehicles
Vehicle less than 8500 lbs. (grams/mile for 120,000 miles/11 years)
NMOG CO NOx PM HCHO
LEV 0.090 4.2 0.07 0.01 0.018
ULEV 0.055 2.1 0.07 0.01 0.011
SULEV 0.010 1.0 0.02 0.01 0.004
Thanks for allowing a rational debate to happen n578md. I've learned a few things researching trying to argue w/ you. I welcome any contributions you can offer to the subject. heres some other emissions technologies coming under way (electric heated cats, NOx traps, etc.):
http://www.aecc.be/en/next_technology.htm
Mods: Is this too far off subject?
