Aerostar Ford Aerostar
Trip Computer
Old Mar 4, 2001 | 09:18 PM
old fool's Avatar
old fool
Trip Computer
Old Mar 21, 2001 | 10:57 AM
bulkman's Avatar
bulkman
Trip Computer
Anyone ever tried fitting the trip computer(overhead model) off an 1986 3.0 Aerostar to a 94 4.0? Anyone have a schematic or wiring diagram for the '86 Trip Computer?
The electronic dash off the "94 model does have all the same functions as the '86 trip computer.
Are the '94 electronic(digital) dash and the '94 analog dash interchangeable(same plug-ins)?
Thanks for any input.
Old May 19, 2003 | 05:53 PM
aerocolorado's Avatar
aerocolorado
Trip Computer
I tried fitting a trip minder from an earlier Aerostar with digital electronics to one with analog gauges. Even though the input sensors from the various areas (fuel sending unit & speed sensor) are analog driven, the trip minder does not accept the data correctly. It works, but the data is not correct. For example, the recorded speed seems to be off by a factor of 10. It reads 1,2,3 mph instead of 10, 20, 30 mph. The fuel economy however, was outstanding, recording 99 mpg at an average speed of 3 mph.
I temporarily spliced into existing wiring, since the correct connector(s) are not found on non-digital wiring harnesses. In doing so, the dreaded anti-lock gremlins were disturbed and announced their presence by lighting up both the red and yellow warning lights. Needless to say, it all came back out and everything is back to normal.
Bottom line: There must be an additional data chip within the digital dash panel that feeds converted data to the trip minder.
Old Feb 11, 2006 | 07:41 PM
cookkd's Avatar
cookkd
Just went through this exerecise....got all the wires hooked up except for one. The EEC input (fuel flow)....aero if you could tell me where you found that wire I would be grateful.....
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
