Can I do this?
Old Sep 15, 2004 | 09:41 AM
wickymustang's Avatar
wickymustang
Can I do this?
I have a 95 F150 with the M5OD and 3.55 tow package. I am wondering if I can start on in second on a flat surface, unloaded. My uncle said that is is fine and that I have a granny first. Everything else I have seen/read/heard says otherwise, that I should start in 1st all the time no matter what I do. So who is right?
Old Sep 15, 2004 | 11:01 AM
EPNCSU2006's Avatar
EPNCSU2006
The M5OD does not have a granny first. I don't know what it is like with the 3.55's but I know with my dad's 2.73 rear gear, it takes a lot of slipping the clutch to take off in second. I would say start in first.
Old Sep 15, 2004 | 12:24 PM
cmlind's Avatar
cmlind
I agree. Mine slips a lot starting from 2nd also with 3.08 gears. With the M5OD, start from 1st.
Old Sep 15, 2004 | 06:56 PM
jim henderson's Avatar
jim henderson
I am guessing here since I don't know your model.
If your engine RPMs wing up really fast, say 5,000RPM by the time you get to 10mph, you might have a "granny" gear since you have a tow package, so you might be able to skip 1st. Some cars come with 1st lockout and start in 2nd. But in general I would go with the normal 1-2-3etc shift unless, you were really winging the engine.
If you start in 2nd all the time and if your truck isn't designeed for it, you might wear out the clutch prematurely.
Best bet is read a manual and listen to your engine when it talks to you.
Jim Henderson
Old Sep 16, 2004 | 12:04 AM
SoCalDesertRider's Avatar
SoCalDesertRider
The ZF is the 5speed with the granny gear. The other 5speed is not a granny tranny.
Old Sep 16, 2004 | 05:53 PM
wickymustang
If I leave it in first and go to 10mph I am redlining it, and have to shift.
Old Sep 16, 2004 | 06:13 PM
andym's Avatar
andym
The M5OD definately does not have a granny gear. Never did.
The ZF swap has been done, so it's a remote chance that you have one. Crawl under the truck and look at the tranny. It will have ribs on the side of it. They're either up & down or diagonal. Diagonal is the ZF, up & down is the Mazda.
Old Sep 16, 2004 | 08:09 PM
wickymustang
They are up and down, and the door code is for mazda, but then why am I redlinning at or before 10 mph?
Old Sep 16, 2004 | 08:14 PM
jessfactor's Avatar
jessfactor
is it possible that your clutch is going. then engine may me redlining, but if the clutch is done it may not be turning as fast as it should due to slipping.
natedowney
15
Nov 20, 2014 05:44 PM
Charliewiltshire
Jun 18, 2012 11:33 PM
babybluef100
Aug 15, 2009 01:05 PM
ACHANDLER
New Member Introductions
Dec 20, 2006 10:37 AM
tazmania18235
Jun 20, 2005 11:14 PM
