1978 - 1996 Big Bronco
Water Pump Replacement Help
Old Sep 21, 2004 | 06:08 PM
  #31
djjoshuad's Avatar
djjoshuad
heh, apparently those bolts break really easily, but others on our trucks do not. I've been trying for 2 days to break off the bolt on the rear leaf spring hanger. I've used a steel cutter and an air hammer to no avail. If the head would just break off like the water pump bolts, I could punch it through and replace it. stupid bolts.
Old Sep 21, 2004 | 09:09 PM
  #32
doc_nomad's Avatar
doc_nomad
Originally Posted by dino360
I know exactly what you mean, I went to ford and they wanted to charge 19.95 for the one that I broke. What I did was go to my friend's mechanic shop and ask if he had anything laying around. I was lucky enough to find 2 of the three I needed there. For the third one, I went by the scrap yard and found an engine laying on the ground that had the bolts I needed. I was lucky. Try going to the scrap yard, that might be your best bet.
I went to NAPA and got some grade 8 bolts the same length. I hope it works, the one on the drivers side with the Power Steering Pump/AC compressor bracket allignment pin is the only one that concerns me. I dont think this really holds anything though because there are 3 big bolts holding the bracket to the pump. I guess I will find out.
ARP has the bolt set, but they were like $50 when I checked.
The thing that bugs me about this is that its not like we are working on a 1928 Buggitti. Isnt Fords saying something like "Americas #1 selling truck"
Old Sep 21, 2004 | 09:23 PM
  #33
dino360's Avatar
dino360
Angry
I don't know, those bolts you are refering to are hard to find because they have different size threads on both ends. I hope it works out for you.
Old Sep 21, 2004 | 10:22 PM
  #34
doc_nomad's Avatar
doc_nomad
Theres nothing attached to the other end of the bolts though, There are at least two bolts with threads sticking out on the passengers side, but there is nothing attached, there are threads on both ends but I cant figure out why. I went to my 68 'stang and pulled out a couple of bolts, same size, just a little shorter.
Old Oct 13, 2004 | 11:05 PM
  #35
jomo924's Avatar
jomo924
why would u take out the shroud to do a water pump???? u remove the fan and lay it carefully in the shroud then remove pump
geez
Old Oct 13, 2004 | 11:10 PM
  #36
JBronco's Avatar
JBronco
Originally Posted by doc_nomad
a 1928 Buggitti
What's a Buggiti?
Old Oct 13, 2004 | 11:20 PM
  #37
doc_nomad's Avatar
doc_nomad
I cant Spell, How about Bugatti?
Old Oct 13, 2004 | 11:23 PM
  #38
doc_nomad's Avatar
doc_nomad
geez
Shroud is only 2 bolts, its nice to have it out of the way. Especially mine because a bunch of bolts broke and I had to pull the Harmonic Balancer to get the timing cover off.
Old Jul 19, 2006 | 05:32 AM
  #39
b4hntn's Avatar
b4hntn
Heat is your friend. Before you break off the water pump bolts slowly heat the block where the long bolts attach. I broke off one before I tried heat. I was able to get vice grips on it after removing timing cover. Then tried a little heat while rocking bolt back and forth. Replaced it with 5/16 all thread and locktite on a nut for the bracket alignment bolt.
Old Jul 19, 2006 | 12:49 PM
  #40
andym's Avatar
andym
You know this thread is two years old, right? I doubt he's still waiting for an answer.
Old Jul 19, 2006 | 01:07 PM
  #41
b4hntn's Avatar
b4hntn
Hmmmmm....where is a date stamp? Thanks.
Old Jul 19, 2006 | 01:12 PM
  #42
andym's Avatar
andym
Upper left hand corner of every post.
Old Jul 19, 2006 | 02:40 PM
  #43
poffutt's Avatar
poffutt
Red face
Lets drop this thread!
Old Jul 19, 2006 | 11:45 PM
  #44
BRAWLNBRONC's Avatar
BRAWLNBRONC
You might want to look for zip ties or wire holding it on maybe someone did a little custom fab and there just outta sight !
