Painting Frame
Old Mar 23, 2006 | 08:01 AM
Js75F250's Avatar
Js75F250
I was planning on taking the bed off and either wire brushing or blasting up until the cab. From there I was not sure. I really don't feal like lifting off the cab. I would then wire brush as much as I can under it and finish it off with 2 coats of rust neutralizer, 2 coats of primer and two coats of paint. Would that be sufficient? Are there any tips for getting the upper side of the frame under the cab? Any additional information would be helpful. The truck is excellent otherwise and the frame is only surface rusted so I would like to stop it there. Thank you, JIM
Old Mar 23, 2006 | 08:39 AM
teds74ford's Avatar
teds74ford
I took my cab off to get the top of the frame. I think a guy on here posted that he but 4x4 blocks on his frame to raise the cab and painted it, but that sounds like a hassle. If you don't raise it, then there is only about 1" of clearance, and it is hard to get a brush in there.
Redeyeracing
Aug 13, 2016 11:53 AM
1978crewcab
Paint & Bodywork
May 19, 2016 01:31 PM
SpedKid94
18
Aug 29, 2015 04:26 PM
HouBill
Jan 3, 2014 11:54 PM
rangermike
15
Mar 3, 2009 11:04 PM
