Aerostar Ford Aerostar
brakes.
Old May 2, 2001 | 11:54 AM
bjjackson_99's Avatar
bjjackson_99
brakes.
Hey guys i have 93 Aerostar with about 80,000 miles running strong, however yesterday it started this really odd deal where when you depress the brake pedal the radio dims and the interior dash lights come on and the park lights come on this is really weird what should I do? is it harming anything?
Old May 3, 2001 | 05:44 PM
aerocolorado's Avatar
aerocolorado
brakes.
Weird! You might try the Electrical Systems/Wiring Conference
Board further on down under Conferences,Misc. Do a search there and see if any other Ford products have similar problems.
Old May 3, 2001 | 07:39 PM
cw016's Avatar
cw016
brakes.
I had a similar experience (dash lights came on when applying the brakes, front parking lamps came on when applying the brakes, etc). I was sure there was some terrible electrical problem. However, it turned out that I had a bad tail lamp. When I pulled out the bad bulb I noticed that both elements had fused together. When I replaced the bulb, the problem was solved. Apparently the fused elements create a ciruit and the current is fed back through the tail lamp bulb. You very well may have a $2.00 problem! Good luck.
Old May 4, 2001 | 12:01 PM
bjjackson_99
brakes.
Thanks for the help man, i really appreciate however i havent even checked it yet now that i think about its either that or another guy told me it very well could be my wiring harness.
thanks...
Old May 22, 2001 | 11:30 AM
cw016's Avatar
cw016
brakes.
Well, it's been a couple of weeks. Have you found the problem yet?
Old May 23, 2001 | 02:29 PM
Mikeman's Avatar
Mikeman
brakes.
jle70
Oct 6, 2013 02:31 AM
1981Ranger
Sep 22, 2013 06:56 AM
hawgystyle
15
Jun 24, 2011 11:11 PM
conchstew
Nov 3, 2007 09:13 PM
Terrie
Jan 17, 2004 11:02 AM
