Brake Light Issues
Old Jun 22, 2011 | 10:41 PM
hawgystyle's Avatar
hawgystyle
Brake Light Issues
On my 1993 F-250 w/ 7.3L. About a month ago my brake lights wouldn't come on unless I pressed really hard on the brakes but now they wont come on at all no matter what I do. Turn signals still work and parking lights still work. I have no idea what this problem can be and I need all advice from simple to complex please.
Old Jun 22, 2011 | 10:56 PM
Jaime74656's Avatar
Jaime74656
have you checked the basics like wiring for fulty connections, fuses, relays, could be a bad relay and/or wire or possibly the switch (i think?) if any for the break/light connection may be bad, thats what i would look at first is relays and wiring then fuses
Old Jun 22, 2011 | 11:05 PM
hawgystyle's Avatar
hawgystyle
Well I havnt checked anything. I just replaced the whole fuel system after breaking down in Georgia And i just got home and thats when I noticed my brake lights didnt work at all. I'll check them tomorrow when I have some daylight. Thank you very much. All this repair work shot my brain and I cant think clearly anymore
Old Jun 22, 2011 | 11:15 PM
White 97 xlt's Avatar
White 97 xlt
Check the brake light switch!!!
Old Jun 22, 2011 | 11:18 PM
rikard's Avatar
rikard
Check the brake light switch mounted above the brake arm under the dash. Check the ground wire for the rear light fixtures too.
regards
rikard
Old Jun 22, 2011 | 11:48 PM
Jaime74656's Avatar
Jaime74656
yep, just checked my haynes book (yes and there should also be a switch which i was refering to in my first post) connected to the break pedal that you should check first along with any relays/wires, if that switch is bad you could see these type of issues (its 00:47 in the morning so im tired guys)
Old Jun 23, 2011 | 10:47 PM
hawgystyle's Avatar
hawgystyle
Well i took a look at the switch and from just eye balling it. it seems to be ok. but i played around and the brake light comes on after a few pumps on the brake pedal but only for five seconds and it turns off
Old Jun 23, 2011 | 10:50 PM
Jaime74656's Avatar
Jaime74656
ok so there may be a short some where between the switch and break lights
Old Jun 23, 2011 | 11:00 PM
hawgystyle's Avatar
hawgystyle
whats a good way to test for a short? would a leak in the brake line cause all this too?
Old Jun 23, 2011 | 11:03 PM
Jaime74656's Avatar
Jaime74656
a leak at most should cause loss of fluid(s) get a tester that a light (for get the name of it) and a multi reader.
Old Jun 23, 2011 | 11:09 PM
hawgystyle's Avatar
hawgystyle
What wires should I test. Sorry Im not good with electronics.
Old Jun 23, 2011 | 11:17 PM
Jaime74656's Avatar
Jaime74656
can you take a pic of the wires in question, im not 100% sure as i have a '95 not a '97 but generaly the wires you want to test are red and black red=hot and black=ground, there may be other wires that may be involved, so others should hopefully chime in that may have more knowledge
Old Jun 24, 2011 | 10:32 AM
White 97 xlt
The switch can be as pretty as it was the day it was made, what you are not seeing is the brunt contacts inside...
Old Jun 24, 2011 | 12:01 PM
87 XLT's Avatar
87 XLT
Does your cruise control shut off when you tap the brake??? If it doesnt, check the brake light fuse. If the fuse is OK the brake light switch is most likely shot.
Old Jun 24, 2011 | 10:45 PM
hawgystyle's Avatar
hawgystyle
Well everything is working now. It was a bad connector that went to the Brake switch. Thank you everyone for your help
