Sponsored by: Real Truck
fuel tanks
Old Sep 14, 2004 | 12:28 PM
bdnorth77's Avatar
bdnorth77
Question fuel tanks
I have a 99 f350 cc, srw,lwb with a 38 gallon tank and just purchased an 02 f350 cc, drw, 4x4,swb and it seems to have only a 25 gallon or so.
I would like to swap tanks before I sell my 99 so that I can get more miles per tank.
Are the tanks interchangeable and how much work will it require.?
I was getting about 780 miles /tank on the 99 and only get about 450 on the 02.I'm trying to go further with less fillups.....
Thanks
in advance...
Old Sep 14, 2004 | 12:32 PM
Frobozz's Avatar
Frobozz
The longbed tank won't fit in the shortbed trucks, sorry.
People like Transfer Flow make bigger replacement tanks you can swap in - I've got a 46-gallon Transfer Flow tank in my 2003 F250 CC shortbed.
Duncan
Old Sep 14, 2004 | 12:46 PM
bdnorth77's Avatar
bdnorth77
I measured the length and width and they are the same,just didn't know about the top..I have no clue...How much are the tanks you speak of?
Old Sep 14, 2004 | 12:51 PM
FortyFords's Avatar
FortyFords
are these aft of the rear axle or inside the frame rail driver side?
as long as the filler is in the right location ,you'll be fine.
Rich
Old Sep 14, 2004 | 01:06 PM
Frobozz's Avatar
Frobozz
Mine was a little under $700, plus installation. It's built like a tank.
Duncan
Old Sep 14, 2004 | 09:05 PM
bdnorth77's Avatar
bdnorth77
My tank is on the driver side.what are you talking about filler ?
Old Sep 14, 2004 | 09:12 PM
FortyFords's Avatar
FortyFords
If your fill tube is in the same pos as the swap tank ,your good to go .
Just change them. and use the the straps from each tank .Whats the big deal?
Unless your not describing something right(like a cross member in the way)
Rich
Old Sep 14, 2004 | 09:24 PM
bdnorth77's Avatar
bdnorth77
havn't looked that closely .the filler is on the same side and my guess would be same location on the tank,but cannot see the top of the tank,....
Thats why I am asking in here...To find out if they are innerchangeable between 99 and 02,also drw,sb-4x4 to srw,lb-2wd..
Old Sep 15, 2004 | 07:48 AM
Sport45's Avatar
Sport45
Like said before, I don't think youcan swap the long bed (38 gallon) tank in place of the short bed (28 gallon) tank. Look at a long bed and a short bed ord side-by-side. The filler is much closer to the rear wheel well on the short bed. If you were able to get the longer tank under there, the fill hose would run up under the cab and it would take forever to fill.
brycelg
Dec 15, 2008 12:46 PM
86F150302
Jul 4, 2008 11:42 AM
Moe Howard
6.4L Power Stroke Diesel
Sep 4, 2007 01:17 PM
SPL Tech
Jan 13, 2007 09:27 AM
ASE
Aug 2, 2004 04:22 PM
