Bronco II Ford Bronco II
egr solenoid
Old Sep 13, 2004 | 03:11 PM
dogg16's Avatar
dogg16
Question egr solenoid
Before I replace this solenoid.... I did a vacuum pump test on it,it gets vacuum,but doesn't seem to put any out..it doesn't hold vacuum when I pump vacuum into the bottom or top valves does this mean its no good ??
Old Sep 13, 2004 | 06:30 PM
nijwnfi's Avatar
nijwnfi
check out technical information in this forum- wish I would have,I bought one for nothing!
Old Sep 15, 2004 | 04:57 AM
warmgravy's Avatar
warmgravy
Just replace the whole EGR unit. When this thing goes bad, you could end up spending weeks diagnosing the engine. I don't know what the original problem is, but my 85 BII had overall poor performance. I spent weeks (one day a week) tuning the carb, new plugs and wires, blah blah ... Turned out the EGR was clogged with carbon and failed. Bought a new valve ('cuz your not suppose to clean it ,just replace) and found the bad valve killed the solenoid. Just change 'em both and start at square one. Hope this helps.
Old Oct 4, 2004 | 11:09 AM
tee's Avatar
tee
I'm been checking everything for weeks too. Did replacing the solenoid clear your codes. I guess my next job is replacing that.
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
4x4x
Jan 23, 2013 06:07 PM
mmenzies
Nov 7, 2012 12:02 AM
CodaMan
Feb 25, 2011 09:04 PM
fmc400
May 23, 2004 06:47 PM
