Sponsored by: Real Truck
4X4 System Troubleshooting
Old Feb 23, 2011 | 06:50 PM
CodaMan's Avatar
CodaMan
I have a 2006 F-250 4X4. The transfer case goes into 4X4 Hi/Lo when the switched is moved, however the hubs won't auto lock. They will lock manually without a problem. I checked the vacuum at each hub when switching to 4 Hi and no vacuum is present. The owners manual doesn't have much information.
Can someone assist? I'm looking for a system schematic or a link to one. There also must be a vacuum pump and some type of solenoid to activate it; where are those parts located? How about a fuse? fuse number?
Any help would be greatly appreciated.
Thanks in advance...
Old Feb 23, 2011 | 07:11 PM
tinman565's Avatar
tinman565
Sir...do a search for "ESOF" in this section. Tons of info to read. I guarantee you'll find your problem.
Old Feb 25, 2011 | 09:04 PM
CodaMan's Avatar
CodaMan
All fixed. Here's what I did:
1) Made sure the vacuum pump and the reservoir were working by just making sure it stopped running a few seconds after the key was put in to the run position and that it didn't cycle.
2) Disconnected the vacuum line from the solenoid and connected a vacuum gauge to the solenoid, switched to 4Hi and watched. Once the dash light illuminated the gauge went to 12 in.Hg for about a minute. When switched back to 2Hi and the dash light went out, I got about 7 in.Hg for about 15 seconds.
3) Connected a hand held vacuum pump ($23 from Harbor Freight) to the line coming off the solenoid, tried to pump it up -- nothing.
4) Isolated the left/right sides by capping one side of the "Y" fitting located under the vehicle.
5) Pumped it up, held 15 in.Hg for about a minute -- Left side good
6) Isolated to the right, Pumped it up -- nothing
7) Looked for a damaged line didn't see anything.
8) Connected the hand held vacuum pump to the right side hub, pumped it up -- Good (hub is not leaking)
9) Replaced vacuum line from right side hub to "Y" connector.
10) Tested -- All good
Found a small pin hole in the right side vacuum line halfway between the "Y" connector and the hub.
System Repaired (total cost = $12.89)
Akflyboy
Dec 13, 2016 01:44 PM
Bigred16
Apr 28, 2016 10:51 PM
Jxltrucking
Jan 4, 2016 02:54 PM
deputydog03
Dec 10, 2015 07:40 PM
