I dom't think you can make the cel go out, the computer knows thew egr is not functioning.
I unplugged mine a ways back and everything has functioned fine since. So, I plugged it back in and I hooked up a diagnostics analyser today, and it did not show any evidence that it had been unplugged, so after the electronic look, I unplugged it again.
There must be a way to throw a electronic loop or resistance on the plug to fool it into thinking it's plugged in without buying a whole new dummy EGR to plug it into.
Now you are thinking Dogdoo. The problem is part of the EGR electronics is an EGR Valve Position Signal with a range of 0.6 - 3.5 depending on position that will correlate with the PCM. The device would have to be smart enough to match up with the position the PCM thinks the EGR valve should be.
