Cab Swap
Old Sep 13, 2004 | 07:51 AM
racenitro's Avatar
racenitro
Cab Swap
What is the latest cab and front clip that will fit a 1983 F-250 4x4 chassis?
Want to update the cab but do not want to loose the chassis. I want to keep the IDFS since I use 4x4 on daily basis and the DIFS is an absolutely necessary item.
Solid front axles won't work in my business.
Old Sep 13, 2004 | 08:33 AM
sandrat's Avatar
sandrat
I should think a 97 f-250 or 350 cab would work As far as I know it's the same (or similar) frame.
Old Sep 13, 2004 | 10:43 AM
william_ace's Avatar
william_ace
just out of curosity, why wont they work?
Old Sep 13, 2004 | 01:16 PM
andym's Avatar
andym
Some info for you - all 4x4 F-250's up until 1999 are IFS. All 4x4 F-350's from 1980 to 1986 1/2 are also IFS.
As far as the cab question, anything from 1980 to 1996 or 1997 will work. The 1997 3/4 ton and 1 ton trucks used the 1992-1996 body style.
Old Sep 14, 2004 | 10:17 PM
racenitro's Avatar
racenitro
I have had several brands and types of 4x4's over the past 30 years. I have found that the IFS front works much better for me. My F-250 weighs in at voer 8000 lbs and is used int 4x4 mode on a daily basis. It seems to climb steeper hills than my old solid front trucks and negotaites strip hills and woods/swampy areas better.
Why do I not just change chassis and cabs....would probably take me a month to remount all the equipment. Has a utility bed, Large bumper that is used to push over trees, special winch mount, special snow plow mount to clear the large bumper, numberous electrical hook-ups...welder on bed, and more. Easier to change cab., That usually takes me a day at the most.
RustyShackelford
WTB - Parts & other
Oct 18, 2010 01:07 AM
jowilker
Dec 5, 2007 06:44 AM
DEBuckingBulls
Nov 28, 2006 09:53 AM
mositso
Jan 24, 2003 10:54 AM
