Tires Fit?
Old Sep 12, 2004 | 07:27 PM
StillaKilla187's Avatar
StillaKilla187
Arrow Tires Fit?
Hey I have an '83 F-150 4x4 with a 3 inch body. I just bought it and it only has 28" tires on it. I would like to have at least 33s, do you think 35s will fit? And what brand should I get. Im not too experienced with this seeing how I turned 16 on the 7th. thanks for any help.
Old Sep 12, 2004 | 07:35 PM
Boss500's Avatar
Boss500
32's will definately fit, 33's probably will too, but I doubt 35's would. I would suggest a regear with 35's anyways. If I were you, I'd go with 32x11.50 Kumho Venture MT's or Firestone Destination MT's. It would look even sweeter if you could find a tire that comes in 32x12.50
Old Sep 12, 2004 | 07:36 PM
Jimbare's Avatar
Jimbare
all alone in the world
35s will probably rub on the front of the fenders. 33s will fit nicely with the body lift.
brian_06328's Avatar
brian_06328
I just got rid of my '89 Bronco (Full size) that had a 2" suspension lift and 33x12.5s with tons of room. I did rub a little turning to the locks, but it wasn't bad.
Old Sep 12, 2004 | 07:48 PM
82F100SWB's Avatar
82F100SWB
35's fit my buddy's 84 with just a 3" BL quite nicely, just had stock replacement front springs, and an add a leaf in the rear(stock springs were worn out)
http://www.bigblocksix.com//f100swb/pics/ryanspos.jpg
Old Sep 12, 2004 | 08:19 PM
bremen242's Avatar
bremen242
also, new poly bushings also give you more clearance. You'd be surprised on how much room you'd gain.
Old Sep 13, 2004 | 07:49 PM
JoeDaddy15's Avatar
JoeDaddy15
My '83 f-150 has sagging springs, and 33's fit on the rear. Still trying to get em to fit the front, though.
Old Sep 13, 2004 | 08:49 PM
TUFFY's Avatar
TUFFY
On my 80 f-250 4x4 2in body lift i,ve got 36-12.50-16.5 no probelm's
Old Sep 14, 2004 | 12:09 PM
Katmandu's Avatar
Katmandu
Question
My 84 F250 4x2 has 33" all around with NO extra lift. I'll get pics soon.....
Old Sep 14, 2004 | 10:29 PM
mustange70's Avatar
mustange70
you can fit 35's no problem with a 3 inch body lift. I have 35" bogger on my 81 mudder and once i cut out the body lines (picture in gallery) and the tires clear other than they hit the leafs cause the 16.5x12 wheels have to much backspace.
Old Sep 17, 2004 | 03:31 PM
StillaKilla187
cool thanks guys
