Sponsored by: Real Truck
Need Help & can't wait
Old Sep 12, 2004 | 06:43 PM
Fordman Dunn's Avatar
Fordman Dunn
Question Need Help & can't wait
I Have A 2001 Superduty Pwerstroke And I Can Not Get It To Start I Turn The Ignition Over And All I Hear Is Clicking Under The Dash If This Is A Relay What Is It Called
Old Sep 12, 2004 | 06:45 PM
Fordman Dunn
Anyone Here This Evening
Old Sep 12, 2004 | 06:48 PM
ryaneverk2's Avatar
ryaneverk2
Hi, and welcome to FTE.
It usually takes people a little longer than 2 minutes to reply, so be patient.
Also, I'd recommend posting this in the Superduty forum, rather than the announcement/introduction forum. Technical questions should be posted there.
Old Sep 12, 2004 | 09:00 PM
Mil1ion's Avatar
Mil1ion
This forum is for introductions not for tech questions.
You also only waited 2 minutes to ask if anyone is around. Why ?
Once you ask a question on a Tech forum,try Being patient.
This is a free web site where people do other things during the day,like spend time with their family
Old Sep 12, 2004 | 09:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Sep 12, 2004 | 10:00 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Sounds like you have a weak battery to me. Put a jumper on it or hook up to another vehicle and see what happens.
Old Sep 13, 2004 | 05:39 AM
ryaneverk2's Avatar
ryaneverk2
Fordman, do your dash lights dim when you try to start it? If so, you may just have a low battery, and need a jumpstart. If that gets it to start, but then you keep having this problem, you might have a bad battery or alternator. Also, if that's the case, before you change the battery, be sure to make sure the cables on it have good, clean connections - that's a simple fix, sometimes.
(copied from my post in your 2nd thread, "Clicking Sound Won't Start")
Yeti, or another moderator, three different threads with the same EXACT question have been started by Fordman (which are "Need Help," "Clicking Sound Won't Start," and "Need Help, Can't Wait") - would it be possible to combine the posts from those three separate threads into one thread, so those making suggestions, and Fordman reading them, can better follow the discussion?
Old Sep 13, 2004 | 06:12 AM
f100downunder's Avatar
f100downunder
have had same problem once was loose cable connection at starter and last time the contact plate inside starter was eroded away
