Steering Wheel Removal? Ignition Change!
Old Sep 12, 2004 | 04:36 PM
kansastj's Avatar
kansastj
Talking Steering Wheel Removal? Ignition Change!
Hey, quick question how do I remove the steering wheel on my 82 full size Bronco. I have removed the large nut in the center of the steering wheel. I thought it would just come right off, it didnt. Do I need sometype of wheel puller tool? I'm changing out the ignition switch so any tips on how to do this would also greatly be appreciated. Thanks
KansasTj
Old Sep 12, 2004 | 05:32 PM
Lee Lichterman's Avatar
Lee Lichterman
Yes you will need a puller. They aren't expensive and are easy to use.
Lee
Old Sep 13, 2004 | 10:13 AM
kansastj's Avatar
kansastj
Is there a certian type of puller I need?
Old Sep 13, 2004 | 01:44 PM
nzabka's Avatar
nzabka
I know O'Rielly's rents them for nothing. Basically you pay a deposit and get the deposit back when you return the tool.
Old Sep 13, 2004 | 03:33 PM
lmadore's Avatar
lmadore
Are you replacing the lock or the switch.
You don't have to pull the wheel if you are replacing the switch. It is located towards the firewall on the column. The lock mechanism operates the switch via a small diameter steel rod that runs along the top of the column under the dash.
Old Sep 13, 2004 | 04:59 PM
kansastj's Avatar
kansastj
Im replacing the lock. Thanks for all the replys.
Old Sep 13, 2004 | 10:35 PM
Big ole Dog's Avatar
Big ole Dog
I use my harmotic balenecer puler for the steering wheel as well as flywheels on boat motors as well as their intended use
Old Sep 14, 2004 | 06:11 PM
pchristman's Avatar
pchristman
Quick and dirty junk yard method: instead of removing the nut, screw it out until it extends slightly beyond the end of the shaft; brace your legs and apply pressure with your knees to back of the wheel at the bottom; at the same time, pull top of wheel toward you; then, while maximum pressure is being applied to top and bottom of wheel, strike the nut with a hammer (preferably a soft-face plastic or brass head).
Granted, this is not the proper method, but it will work when you have a wheel to pull, but no puller.
Old Sep 16, 2004 | 03:20 AM
lostaprop's Avatar
lostaprop
That is true junkyard advice. I take friends like you when I go parts scavenging. Best mechanics in a pinch you can have.... The harmonic balancer puller works fine and is inexpensive to rent from your local parts store...
Old Sep 16, 2004 | 03:26 AM
lostaprop's Avatar
lostaprop
fullsleeves2
Sep 5, 2025 09:03 PM
UaVaj
Oct 16, 2014 11:23 PM
WINGNUT-
13
Jun 25, 2014 07:20 PM
boilerperson
Sep 3, 2006 12:08 PM
the Goat
1978 - 1996 Big Bronco
17
Feb 5, 2006 09:41 PM
