fuel gauge issues
Old Sep 11, 2004 | 07:47 PM
lazerus's Avatar
lazerus
fuel gauge issues
On my 72 ford, the fuel guage will not register past 1/2 fuel when it IS full. I switch out the voltage regulator with no effect. When I grounded the pos wire to the tank it did pegged but did so in stages and slowly. Any ideas?? If it is a deffective gauge and can't be fixed and has to be replaced any ideas where to find a 1972 F100 instrument cluster??
Old Sep 11, 2004 | 08:02 PM
ant truck's Avatar
ant truck
Have you checked out the sending unit.Do you have a in cab tank?Ive had trouble with the rubber sock which goes over the brass float ball sticking on the side of the tank.Thats if of course you have that style tank.
Old Sep 11, 2004 | 09:26 PM
lazerus's Avatar
lazerus
did that
Yeah I switched out the sending unit with no effect. Even when I had the unit wired uo "outside" the tank I couldn't get the gauge to register "full".
Old Sep 11, 2004 | 10:22 PM
seabee04's Avatar
seabee04
I have the same problem with my 72 F250. Never did find a replacement. Now everytime I fill the tank I just calculate 8 miles to the gallon! Dont want to run out of gas or pass a gas station.
Old Sep 13, 2004 | 07:40 PM
lazerus's Avatar
lazerus
IS there hope
Is it possible to find a new or used(working) fuel gauge or instrument cluster and if so where??
Old Sep 13, 2004 | 08:07 PM
Jimbare's Avatar
Jimbare
all alone in the world
check the site sponsors,
http://www.truckowners.com/cgi-bin/b...R=autokrafter1
http://www.truckowners.com/cgi-bin/b...COUNT=MACSAUTO
either one should have what you need.
moejr
Feb 28, 2017 05:23 PM
mmenzies
Sep 28, 2016 05:04 AM
IDMooseMan
32
Jun 25, 2007 07:10 AM
amwdrizz
1978 - 1996 Big Bronco
Jan 13, 2004 11:40 PM
lymo
Dec 7, 2003 01:35 PM
