Differential oil additive?
Old Sep 10, 2004 | 04:50 PM
johnydep's Avatar
johnydep
Hi everyone.
I am after some info for a F250 7.3L Turbo, 2003 model.
Changing the diff oils today, I'm using 75w140 GL-5 full synthetic (as required).
On other Ford high performance vehicles I have used an additive; Ford MOTORSPORT Friction Modifier M-19546-A
Can anyone tell me if this I can use this in the F250 LSD diff, back & front?
Also, what type of diffs do these F250's have?
Thanks in advance.
Old Sep 12, 2004 | 02:27 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Your front diff is either a Dana 50, or 60 and takes non synthetic 75w-90. It also is an open differential.
The rear is a corporate 10.5" (Built in Sterling Mich., not Sterling Inc.). You can use the motorsport friction modifier or just abut any other. In fact, a year or so ago the local Ford dealers were recommending the mopar friction modifier as the Ford stuff was too slick. I chose to run mine without any modifier and it works a ton better. It's actually a limited slip now as opposed to the limited grip it was before.
Old Sep 13, 2004 | 07:29 AM
johnydep's Avatar
johnydep
Thank you cookie88, that is a great help.
Myfreeford
Aug 10, 2014 02:08 PM
Brian3676
Jan 10, 2011 05:50 PM
jjed2007
Oil & Lubrication
Feb 27, 2008 02:47 PM
Peter Richards
Jun 16, 2007 09:50 PM
GoCamping
May 11, 2007 06:38 AM
