Aerostar Ford Aerostar
1990 Aerostar
Old Jan 6, 2002 | 05:15 PM
dougas's Avatar
dougas
1990 Aerostar
Terrible gas mileage, blows black smoke out of tailpipe. Idles really rough. Put in new oxygen sensor. Gas gauge fluctuates. Please help. Thanks very much.
Old Jan 6, 2002 | 10:52 PM
EvilAerostar's Avatar
EvilAerostar
1990 Aerostar
WOW Sounds like we have the same Van, I got a 90 with less than desirable gas millage and a little black smoke and magical gas gage.
I have noticed less dark exhaust when I put in a heavyer oil the last time I changed it. I could tell a big difference in the way the engin ran, I need to change it this week and I will telll if there is any deffence.
Jeremy
Old Jan 7, 2002 | 08:21 AM
dougas's Avatar
dougas
1990 Aerostar
>magical gas gage.
>Jeremy
doug did you have any other problems with your van mine seems to be sluggish at a cold idle i only get 300km out of a tank of gas
Old Jan 7, 2002 | 08:23 AM
dougas's Avatar
dougas
1990 Aerostar
Old Jan 7, 2002 | 11:51 AM
EvilAerostar
1990 Aerostar
[updated:LAST EDITED ON 07-Jan-02 AT 12:52 PM (EST)]Every Cold morning its sluggis and some times stall when I give it the gas. A lot of Poeple say you need to clean the TPS Throttel Positing Sensor, sorry I cant spell very well, but I have not tried to clean mine yet.
Jeremy
P.S. I only get about 16 to 18 miles a gallon but some times 20, I can usualy go about 300 miles on 19 gallons of gas.
Old Jan 7, 2002 | 01:37 PM
rsheltro's Avatar
rsheltro
1990 Aerostar
Check your TPS first. Then my next move would be checking the fuel pressure regulator. Does the van suffer from any power loss or surging under load?
Old Jan 11, 2002 | 04:52 PM
nashcar7072's Avatar
nashcar7072
1990 Aerostar
hyave ou had the vehicle scanned for fault codes as ford is great forsensor going but not kicking the light on try unplugging the map sensor and seeing what happen or just plug the vacuum line to it
Old Jan 11, 2002 | 04:54 PM
nashcar7072
1990 Aerostar
Realslowww
Apr 6, 2015 12:53 AM
Corner Gas
15
Apr 23, 2013 08:21 PM
Corner Gas
Aug 11, 2008 10:27 PM
Stephens
Sep 24, 2002 08:49 AM
Just Strokin
Dec 8, 2001 05:10 AM
