Old Sep 9, 2004 | 12:32 PM
IH Willy's Avatar
IH Willy
I have a 429 out of a 72 Mercury. This is right around the big changes in compression. What is the easiest way to guess fuel requirements on this complete assembly? I have the whole motor and transmission to put in a 66 PU.
Old Sep 13, 2004 | 07:15 PM
THalina's Avatar
THalina
What is the casting # on the block and the heads? This will allow us to check the compression ratio the engine came with, and from there figure out the fuel requirements...
Old Sep 14, 2004 | 07:01 AM
IH Willy's Avatar
IH Willy
The heads are D2VEAA. The tag from coil reads 429 72 10
6-23 K814 SG
I have not found the block # yet.
Old Sep 18, 2004 | 11:11 AM
dots's Avatar
dots
should be lower compression than the 71 and older, somwhere around 8.5:1
what size diameter spark plugs does it have?
block number is behind the starter.
Old Sep 23, 2004 | 04:48 PM
scroob's Avatar
scroob
The D2 heads are absolute crap. I would get rid of them ASAP. They have no quench and ping like a turkey, even worse than the D0VE heads with the same fuel. The fact that Ford only made this head for one year should tell you something. You are going to have major pinging problems even with 92 octane gas.
The D3 and later heads are nice low compression heads and can be made to flow quite well.
Old Sep 25, 2004 | 12:36 AM
429littleman's Avatar
429littleman
I got it
I have the same exact engine as u have that i am geting ready to pull out of my 72 mercury marquis demo car. I have all the specs that u need for that engine if u want them i can email them to ya. and no im not crazy even though i ran a 429 in a demo my plan is to rebuild it anyway so why not. but i think i can help
kw5413
Apr 19, 2014 07:54 PM
707crewlover
Oct 20, 2012 09:27 PM
dani9678
Mar 15, 2010 03:32 PM
TX460Bronco
13
Jul 20, 2006 08:16 PM
RichardMaerz69
Mar 7, 2004 11:41 PM
