Offroad & 4x4
Biggest tires?
Old Sep 9, 2004 | 07:57 AM
nidex's Avatar
nidex
Biggest tires?
Hey guys, just wondering.. what are the biggest tires I can fit on a stock height 87 F150 4x4? I know you can do 33's on a Bronco with a little sawzalling, I'm not sure if the F150 would be the same or not.
Old Sep 9, 2004 | 09:20 AM
fishmanndotcom's Avatar
fishmanndotcom
f150 and bronco are exacty the same in the front. ford used f150 platform, they just put a twist on it
you can run 40's
-cutts-
Old Sep 9, 2004 | 10:03 AM
ivanribic's Avatar
ivanribic
Originally Posted by fishmanndotcom
you can run 40's
-cutts-
I take it you mean with the ol' sawzall cutts.
Old Sep 9, 2004 | 10:07 AM
fishmanndotcom
shoot with a sawzall you can run upwards of 46's
-cutts-
Old Sep 9, 2004 | 02:29 PM
JTdesert's Avatar
JTdesert
How much cutting for 33's? Tanked, JT
Old Sep 9, 2004 | 03:22 PM
proeliator's Avatar
proeliator
-cutts-
On a stock 87 150!? Were you planning on cutting out the body mounts too? A sawzall will only take you so far.
You should be fine with 33s. If you have to trim it won't be major surgery.
Old Sep 10, 2004 | 04:57 PM
99ford4x4's Avatar
99ford4x4
what would u be sawzalling?
Old Sep 10, 2004 | 06:42 PM
proeliator's Avatar
proeliator
The fenders....if its even neccesary. I mean, you COULD sawzall the knuckles if you really wanted...
Old Sep 11, 2004 | 01:18 AM
hoxiii's Avatar
hoxiii
on an '87 you;ll probably have to trim the rear lip of the front bumper to do 33's, i know you have to to do 35's.
Justin
Old Sep 11, 2004 | 06:27 AM
JeremyH's Avatar
JeremyH
I tried this, it is quite easy. It makes the steering a LOT easier......almost like I have hydro.
