1992 aerostar
1992 aerostar
You might want to search through recent postings. There were two that I read earlier today that said they had the same problem, that it is common on these trucks, and that it took 3 or 4 hours to replace a part in the steering column, I think.... in any case, there was a firly simple, not too expensive fix.
1992 aerostar
>Thanx for the info i have prolblem fixed it was my trailer
>wires at the reciever hitch shorting out
It wasn't wired using the stock trailer wiring, then. The stock trailer wiring isolates the front wiring from the rear wiring very effectively!
See
https://www.ford-trucks.com/dcforum/aerostar/415.html#1
Regards,
Al S.
See
Regards,
Al S.
1992 aerostar
>expensive fix.
See:
https://www.ford-trucks.com/dcforum/aerostar/242.html#2
Regards,
Al S.
>expensive fix.
See:
Regards,
Al S.
