Offroad & 4x4
Propane vs. fuel injection
Old Sep 10, 2004 | 12:45 PM
  #31
fishmanndotcom's Avatar
fishmanndotcom
<TABLE cellSpacing=0 cellPadding=10 width="100%" border=0><TBODY><TR><TD>
</TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD vAlign=top width="38%" height=2756><TABLE cellSpacing=0 cellPadding=10 width="100%" border=0><TBODY><TR><TD><CENTER>
Here is my propane tank. It sits perfectly between my fenderwells. </CENTER></TD></TR><TR><TD><CENTER>
This is the fuel lock. It allows fuel to enter the vaporizor. It is activated by engine vaccum. I have it mounted on the inside of the firewall. </CENTER></TD></TR><TR><TD><CENTER>
Here is the vaporizor-regulator. It's job is to regulate the high pressure tank LPG down to low pressure vapor. Notice the heater coolant lines running through it. </CENTER></TD></TR><TR><TD><CENTER>
Here is the air/fuel mixer (caburetor) and air cleaner assembly. Notice the large hose going into the top of the air cleaner. This is the actual fuel line into the carburetor. </CENTER></TD></TR><TR><TD><CENTER>
Here is a shot of the throttle linkage. It was the same as my quadrajet carb. Notice the leftover manifold burrtio from a previous trail run. </CENTER></TD></TR><TR><TD><CENTER>
Here is the filler cap where you add propane to the tank. I put it in a nice and accessible area. I decided not to put it in the stock location, because I often grind boulders across that region. </CENTER></TD></TR></TBODY></TABLE></TD><TD vAlign=top width="62%" height=2756><TABLE cellSpacing=0 cellPadding=10 width="100%" border=0><TBODY><TR vAlign=top><TD>So why on Earth would someone want to run propane in their vehicle, when it runs just fine with good old fashioned gasoline? Well, I had several reasons for doing it.
First off, my carburetor needed rebuilding. My gas tank was pretty shot, so I needed a new fuel tank. Not to mention gas prices were nearing $2.00 a gallon. When a friend of mine asked me if I wanted to convert my rig over to propane from a wrecked one ton truck that he had, I was all over it. So with a little reaserching, I dove into it head first. It turns out it was a simple conversion, that anyone can do.
Here are the pros and cons to think about, before making a desicion to go propane:
Pros: It burns much cleaner than gas. No carbon buildup inside your engine. After 5,000 miles, your oil will still look new!
It is MUCH cheaper than gas. As of today, fuel at the corner gas station is $1.69 a gallon. Propane is about $1.10 at the same station. Down the road a little farther, it can be had for $0.89 a gallon!
A propane powered vehicle will run at almost ANY angle. It will run better than a fuel injected vehicle at an extreme angle, because the fuel injected vehicle will die shortly after the fuel pickup in the tank looses fuel. The propane vehicle will run much longer thanks to being a pressurized system. It does however have a fuel pick up at the bottom of the tank, so eventually it will quit running.
A propane system is very simple. Virtually no moving parts, and no computer/electroics to mess with, like fuel injection. No fuel pump, even
<LI>A 103 "pump" octane rating Cons:
Propane is not as readily available as gas, although due to the increase in recreation of all types propane is fast becoming more readily avalible everywhere.
If you live in extremely cold environments (10 degrees F or below) you may need a block heater.
Not everyone runs propane, so you better have enough fuel!
<LI>You need to learn how to tune it, since no one else will know how to!
There are 4 basic parts to a propane system.
1) The tank(pressure vessel). You want a good, NEW tank,or one with no rust pitts deeper than.025" .The tank MUST be ASME approved with the clover stamp clearly visible and have the following: a pressure relief valve,filler valve,bleeder valve(liquid level gauge), a manual shutoff valve,and a fuel level gauge(visual) along with a vapor outlet and a liquid outlet. Automotive propane tanks are very heavy duty, since tank pressures vary from 40 to as high as 275 psig, depending on ambiant/fuel temp.
2) The Fuel Lock: These valves operate by vacuum, engine oil pressure or electrical solenoid.
3) The Vaporizer/Regulator: Also called a converter this little bugger converts high pressure liquid propane into low pressure vapor.
4) The Air/Fuel Mixer: This is a very simple carburetor that mixes air and fuel into the engine. There are three basic types: air valve mixer,the venturi principal mixer,and the mechanical metering mixer. Of course you will also need fuel line to run from the tank to the fuel lock as well. You need to use triple steel braided line that can easily handle the high pressure, minimum 250 psi. Also a must is a Hydrostatic Relief valve in line between any shut-off valves.
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Old Sep 10, 2004 | 12:46 PM
  #32
fishmanndotcom
Where can you find all of these things? The easiest place is your local propane supplier. Places like Amerigas, or Suburban Propane can supply you with all new parts needed for the conversion. For everything new, you are looking at about $800. Or you can find the stuff used. I got all of my stuff from a friend's wrecked propane truck for free. The first step is figuring out where and how to mount your tank. Now remember, this tank is pressurized, at about 200psi. You really want to make sure it's in a protected area, and safe from rocks. If you are going to mount it underneath your rig, build a very stout skid plate for it! For ease of installation and for safety's sake, I decided to mount it inside the vehicle. For added piece of mind, it was securely mounted completely to the vehicle's roll cage. The tank has a Excess Flow valve built into the liquid line valve. This will automatically stop the flow of fuel should a sudden burst in a line occur.
Now that you have the tank mounted, you can begin mounting the fuel lock and the regulator/ vaporizor. You want these to be as close as possible to the carburetor. I mounted mine on the firewall. The vaporizor needs to have your heater hoses plumbed into it. The heat from the coolant keeps the propane nice and warm. If you didn't run coolant through the vaporizor, it would freeze up after a few minutes. You should also have the regulator mounted right next to the vaporizor. Once you have the regulator and vaporizor mounted securely, you can run the high pressure line from the tank to the regulator. Be sure to route it so that it is out of harms way. Keep it away from the exhaust, and away from rocks!
Now that you have the tank, fuel lock and the vaporizor/ regulaor hooked up and mounted, you can install the carburetor. For me, this was a simple swap out. My propane carb matched my previous quadrajet exactly, so I simply removed the old Carburetor, and bolted the propane carb on. The linkage hooked up the same too. No need for a choke anymore, either.
All that's needed to connect the vaporizor to the carburetor is some fuel filler line (see photo). Again, make this line as short as possible, due to the low pressure.
Now that you have everything hooked up, you can remove some of your old stuff. You no longer need your gas tank (duh). You also need to remove your fuel pump, if you have a mechanical one. If you don't want to make a plate to cover the hole, you can leave the fuel pump in place. However, you should remove the push rod that goes from the cam to the pump, since the pump will no longer need to pump.
Now you are ready to fire it up, assuming you have propane in the tank. If not, trailer it over to the local gas station, and sit back while they fill up your rig for you. Yep, you get free full service.
You are now ready to fire it up, and see what happens. When I finished installing my setup for the first time, it was about 20*F and snowing. I turned the key, and it immediately fired up. It idled prefectly smooth, like it had been warmed up for an hour before hand. I was very impressed.
After getting everything setup the way you want, it is recommended that you take your vehicle to a shop that specializes in propane systems for fine tuning. Once again, your local propane supplier should be able to refer you to someone. Here are some technical specs for LPG: <TABLE cellSpacing=0 cellPadding=0 width="100%" border=1><TBODY><TR bgColor=#333333><TD><CENTER>Chemical formula: </CENTER></TD><TD><CENTER>C3H8 </CENTER></TD></TR><TR bgColor=#000000><TD height=2><CENTER>Specific gravity: </CENTER></TD><TD><CENTER>Liquid: .509
Vapor: 1.52
</CENTER></TD></TR><TR bgColor=#333333><TD><CENTER>Weight per gallon: </CENTER></TD><TD><CENTER>4.24 lbs. </CENTER></TD></TR><TR bgColor=#000000><TD><CENTER>Boiling point (atmospheric): </CENTER></TD><TD><CENTER>-44F </CENTER></TD></TR><TR bgColor=#333333><TD><CENTER>Heat Value: </CENTER></TD><TD><CENTER>per cubic foot (vapor): 2516 BTU
per pound (liquid): 21,591 BTU
per gallon (liquid): 91,547 BTU
</CENTER></TD></TR><TR bgColor=#000000><TD><CENTER>Ignition temperature: </CENTER></TD><TD><CENTER>920-1120F </CENTER></TD></TR><TR bgColor=#333333><TD><CENTER>Maximum flame temperature: </CENTER></TD><TD><CENTER>3,595F </CENTER></TD></TR><TR bgColor=#000000><TD height=26><CENTER>Flammibility limits: </CENTER></TD><TD height=26>
Upper: 9.60%
Lower: 2.15%
</TD></TR><TR bgColor=#333333><TD><CENTER>Ideal combustion ratio: </CENTER></TD><TD><CENTER>By weight: 15.5:1
By volume: 24:1
</CENTER></TD></TR><TR bgColor=#000000><TD><CENTER>Cubic feet of vapor: </CENTER></TD><TD><CENTER>per gallon: 36.4 cu. ft.
per pound: 8.6 cu. ft.
</CENTER></TD></TR><TR bgColor=#333333><TD><CENTER>Octane ratings: </CENTER></TD><TD><CENTER>Research: 110
Pump: 103
</CENTER></TD></TR><TR bgColor=#000000><TD><CENTER>Vapor pressures: </CENTER></TD><TD><CENTER></CENTER></TD></TR><TR bgColor=#333333><TD><CENTER>Temperature(F) </CENTER></TD><TD><CENTER>Pressure (psi) </CENTER></TD></TR><TR bgColor=#000000><TD><CENTER>-44 </CENTER></TD><TD><CENTER>0 </CENTER></TD></TR><TR bgColor=#333333><TD><CENTER>-20 </CENTER></TD><TD><CENTER>10.7 </CENTER></TD></TR><TR bgColor=#000000><TD><CENTER>70 </CENTER></TD><TD><CENTER>132 </CENTER></TD></TR><TR bgColor=#333333><TD><CENTER>100 </CENTER></TD><TD><CENTER>205 </CENTER></TD></TR><TR bgColor=#000000><TD><CENTER>130 </CENTER></TD><TD><CENTER>300 </CENTER></TD></TR></TBODY></TABLE>
Old Sep 10, 2004 | 05:49 PM
  #33
ivanribic's Avatar
ivanribic
You pull that off Pirate's tech page Fishy? I know I've read all that somewhere but can't find it again. Good info! I think I shall do propane then for my trail rig, just to try it. Now all I need is a stinking rig. Bronco II that I was going to get sold a couple hours before I got to the dealership. I spent all my money on booze and loose women so now I've got to wait until the winter.
Old Sep 10, 2004 | 10:12 PM
  #34
fishmanndotcom
yes i did, i was tired of posting just links and i know i get tired of following links
-cutts-
Old Sep 11, 2004 | 09:05 AM
  #35
ShawnZ's Avatar
ShawnZ
oh wow, I thought propane would be just a complete pane (pun.heh.) in the rear. But it does have some upside. I have an '85 bronco II that I want to swap a 302 into, I had thought about using propane with it at one time, but was imeddiately discuraged when I heard that there would be a loss in power. But, if it can be made up for with compression (which I dont know what that is :-\) then it might just be worth a shot.
Would it be ideal to buy a crate engine and have it set up to run on propane before I install it? or after?
anyone ever done this with a bronco II?
Old Sep 11, 2004 | 11:19 AM
  #36
fishmanndotcom
The compression stroke is the upwards movement of the piston in the cylinder with the valves closed following the intake stroke. This upwards motion compresses the fuel air mixture inside the combustion chamber raising the pressure. The difference between the initial volume of the cylinder and the final volume at the top of the compression stroke is known as the compression ratio. Typically this is approximately 9:1 in spark ignition engines and 15:1 for diesel engines. The compression ratio is particularly important in compression fired engines such as diesel engines. The fuel-air mix and compression ratio is critical to avoid pre-ignition which is the abnormal ignition of fuel in the combustion chamber before the combustion stroke. In diesel engines the fuel is injected under high pressure towards the top of the compression stroke. The distribution of fuel before combustion is also of interest because it effects the efficiency of combustion
that's the best way i know of to explain it, hope it helps.
-cutts-
Old Sep 11, 2004 | 05:39 PM
  #37
ShawnZ's Avatar
ShawnZ
ok, I figured it was something like that, but im still not sure exactly what it is. what exactly gets 'compressed' when you change the compression ratio, and when you change the compression ratio, and make it say 10:1 from 15:1 would that make it MORE or LESS compressed? When changing the compression ratio to gain power, do you want the compression ratio or be higher or lower?
I heard that there is a different setup (hookup) used when you use propane in a vehicle than there would be when filling one for, say a gas grill cylinder, is this true? And would that not all places that sell propane would have the right setup to pump it into a vehicle? Also, is there a way to have a spare "gas can" type thing with propane, what I mean is, having an extra tank that can be used to fill the normal tank used in a propane vehicle?
Then now, I think it would be a good idea to run a dual setup, just incase I find myself somewhere that doesn't have propane. Someone said it is best to completely convert (or build the engine for the specific use of propane) to run a dual setup, but neither gas nor propane would run very well on it, is this true, and is there a way to make it run great with propane but be able to 'get by' with driving on gasoline if you have to?
What is propane selling for, I havent bought it in years, and the only ones I've noticed are the blue rhino prefilled cylinders for sale.
I think I have more questions, but I just woke up and cant remember them.
Old Sep 26, 2004 | 08:23 PM
  #38
socalfurnow's Avatar
socalfurnow
Excellent info. I've been putting off a number or repairs on my 89's efi. None of it is cheap to replace. Nor am I competent in programming chips etc. The wife and I are a little mindful of the most excellent exhaust that we've been sharing with the world via our 79 'chero and 1960 Rambler. The propane would give us the kudos to deal with all the VW 4 banger friends we have. All I ever hear about is how great the mileage on 4 cylinders etc - it doesn't matter to them we used the bronco to haul out bobcats that got stuck when landscaping or when it had enough space to move 3 people 1200 miles + 2 dogs +2 cats and still had space to stretch out.
I've been thinking of a high compression stroker (383 from my existing 351) with propane. Then of course the need to upgrade the frame for serious towing. Seen some 1 ton kits that look peachy. Clean, affordable, efficient performance. Ahhhh .... these are the things that help me get up in the mornings and put in the 7 days a week I work.
gungho351
Alternative Fuels, Hybrids & Mileage
Jun 15, 2007 01:48 PM
CheaperJeeper
79
May 29, 2007 10:09 PM
thesprocket26
May 25, 2005 12:40 PM
