Aerostar Ford Aerostar
Engine Light
Old Feb 8, 2002 | 12:40 PM
Deeman's Avatar
Deeman
Engine Light
When I´m driving my Aerostar 3.0 -89 a bit hard, 90mp/h.
the "check engine" light, lights up.....
why?
Have ordered the Haynes book so that in next week I can check the ECU for codes,,,,,, but still I wonder?
any ideas?
Old Feb 8, 2002 | 06:51 PM
Avanti's Avatar
Avanti
Engine Light
You are pressing the envelope of disaster with the 3.o at that speed in the Aerostar unless it is a new engine. I have a 93 4.0 but don't press it over 80. If I want to go faster I pull a supercharged two door coupe out of the barn. What could be happening is your oil pressure is dropping because the engine is worn. Or as I have seen in the past the oil is not draining back fast enough to the oil pan. The oil pump is running short of oil. Watch your oil gauage or better yey get a real one. Also you could be running lean because of a weak fuel pump, clogged fuel filter etc. Worn plugs or distributor parts could also cause some fireing problems. Good luck.
Old Feb 8, 2002 | 11:32 PM
asavage's Avatar
asavage
FTE Community Team
Engine Light
Until you can get the ECU to tell you what IT thinks is wrong, you'd be just guessing. Hell, I can pull a rabbit out of a hat: TPS will be my guess (it's my default guess but probably wrong for this symptom), but really, it could be nearly anything. The EGO sensor could go out of spec when really hot. The fuel filter might be getting restricted (though it's plenty large, and will handle a lot of crap in it), or any one of a number of things.
Get the Haynes, count the analog voltmeter sweeps (do it several times, it's easy to make a misteak), and tell us the results -- then we can guess with authority!
Um, 90, eh? I've got the digital dash on my '89, and I've been told it tops out at 85 -- not that I've ever even gotten close to that.
Regards,
Al S.
Old Feb 9, 2002 | 04:50 AM
Deeman's Avatar
Deeman
Engine Light
Ok, I´ll check next week......
I wrote 90mp/h.....
155 Km/h.......thats it top speed, after that there is something that shuts off the engine.......and it should be like that (written in the instructions manual)...
But travelling in about 130-135 Km/h is completely easy......then just press the pedal to the metal....and some seconds later.......155.... and thats it........
I´got rid of my drivers lisence for 5months last year....... was ticked at 152Km/h on a "110 road"..........
I´m satisfied with that...... but I can feel that It´s not completely right.......something is missing when I "step on it"........
The fuel filter, is new.....EGO is 6months...airfilter is new.....
Plugs are 6months (20 000Km)........Car is 246 000 miles........but distributor/cap and wires.... i´ve never changed themm, but will see first what the ECU tells........
last night I disconnected the battery and erased the ECU´s memory.......
Then when I drove it after that...(easy for a while)......then pushed it a bit........there felt like much more power than before....but after a while......."check engine".......
Will see....
Old Feb 9, 2002 | 08:48 AM
Deeman's Avatar
Deeman
Engine Light
Sorry.something went wrong there.. didn´t mean I was satisfied with loosing drivers lisence-.....
Old Feb 9, 2002 | 09:01 PM
Cardude_mad's Avatar
Cardude_mad
Engine Light
i think you push it too much. for a vehichle with 246,000 miles on it, i'm surprised the motor hasn't quit on you yet. i would slow it down a little if i were you. mine is a 92 and it shuts off at like 100 or so. yes i have had it up there, but i don't make a habbit of it, in this type of vehicle it is far too dangerous. but never-the-less fun!!!!!
Old Feb 10, 2002 | 04:33 AM
Deeman's Avatar
Deeman
Engine Light
With Bilstein shocks .it´s no match.
the speed is normally about 75mp/h.......
ok//
Old Feb 10, 2002 | 11:29 AM
asavage's Avatar
asavage
FTE Community Team
Engine Light
[img src="http://www.tfhrc.gov/trnsptr/feb98/r2-1.jpg"]
Old Feb 10, 2002 | 09:41 PM
dzk007's Avatar
dzk007
Engine Light
I've got a 3.0 '89 aero also. The darn thing looks like it was dipped in acid cause of rustout but it still does 90mph if given enough time to do it. had it there last week. not bad for 155k. i like the motor so much, I'm gonna rebuild it better than stock and put it in my '84 Bronco II this spring. I'm thinkin that you might be having a cat clog starting after all those miles. Keep us posted
Old Feb 11, 2002 | 07:23 AM
Deeman's Avatar
Deeman
Engine Light
cat clog?
it means.... exhaust´s getting a hard time to get out, or?
I´m not completelt sure if my engine is original or maybe rebuilt....?
Previous owner said it was but you can never know=)
But it´s just like if it were NEW... handles so well, 90 is no problem and that is on tires 205/70/14.....C
So i dont know............but something is wrong....
I´ll be back!!
Old Feb 12, 2002 | 11:47 AM
Deeman's Avatar
Deeman
Engine Light
Hi!
Checked the ECU to day.......
and three codes apeared,,,,
52, 77 and 74......
nothing else!......
52 because the power steering pump is DEAD!
and 77,74 because I didn´t break,,,,,,,,???
Glad that there was nothing wrong..........
Maybe the Check Engine Light felt that there was something with the PSPS.......Power Steering?......maybe....
Well see just have to fix that first!
Old Feb 13, 2002 | 12:30 AM
asavage's Avatar
asavage
FTE Community Team
Engine Light
