Sponsored by: Real Truck
Need help, Washer pump not operating.
Old Sep 7, 2004 | 05:59 PM
Jesters Court's Avatar
Jesters Court
I have a 99 F250 CC with the v-10. My front windshield washer is not working. I didn't want to start tearing apart things until I posted. Did anyone else have this problem? Is it usually the pump or the multi-function switch? It appears the pump is under the fluid reservoir. Do I actually need to pull the battery and reservoir to test voltage to the pump? Any ideas or fixes?
Joe
Old Sep 7, 2004 | 08:43 PM
huntercgr's Avatar
huntercgr
Are you sure your "squirt lines" aren't plugged?
Old Sep 7, 2004 | 09:20 PM
FortyFords's Avatar
FortyFords
Ithink you can loosen the front inner fenderwell and get to it.
you looked at fuses 54 and 33
Rich
Old Sep 8, 2004 | 06:58 AM
Jesters Court
Yeah. I blew through the lines and they were clear, fuses are good. When I push in the multi-switch to activate the washers I expect to hear at least a click or a whine but hear nothing.
Joe
Old Sep 8, 2004 | 10:13 AM
Jesters Court
OK, got in the truck today and guess what, they are working again. This might be worse than them not working at all. Diagnosing intermittent troubles are a pain in the a**.
Joe
Old Sep 8, 2004 | 10:38 AM
1081's Avatar
1081
I would guess the pump is probably going out. If it is it will quit again.
Old Sep 8, 2004 | 12:10 PM
FordRuss's Avatar
FordRuss
Where's the ground for the pump motor??? I had one grounded to the chassis via the resevoir mount & that screw was loose.. Pump only worked intermittantly until tightened..
Good Luck,
Russ
Booboo59
Jul 11, 2011 09:14 PM
SuperSnake
Aug 11, 2008 02:59 PM
pdqford
Apr 1, 2008 11:19 AM
dotcentral
Oct 3, 2003 02:34 PM
eclectix
19
Aug 18, 2003 12:50 AM
