Bronco II Ford Bronco II
smooking oil
Old Sep 7, 2004 | 05:15 PM
jclopezv's Avatar
jclopezv
smooking oil
My little truck have been leaking oil for a while, I believe it's from the valve cover gaskets. After driving it for 5 minutes, the smoke is always visible, (coming from the under the hood, not big deal). Now, today I notice that the smoke was more visible than usual and I smell it even from the inside while I was driving. I open the hood and notice that a large amount of smoke was coming from a single piece (see the pict). What is that piece? is it something to be worry about?
Thank you
JC
p.s. The smoke only comes from the engine, no from the muffler's tail pipe.
https://www.ford-trucks.com/user_gal...&albumid=12035
note: I am not sure if the picture will shows up. I put the pic in my gallery and link it to this post.
Old Sep 9, 2004 | 02:02 AM
mrshorty's Avatar
mrshorty
Kind of hard to tell from the pictures, but that looks like the place where the EGR tube connects to the exhaust manifold. Is that right? If so, is the EGR tube in place (can't tell from the picture)? Is the smoke coming from oil burning off of the surface of that part, or is it exhaust fumes escaping from the exhaust?
Old Sep 9, 2004 | 11:52 PM
plilikoi's Avatar
plilikoi
I had the same problem. You need new valve cover gaskets.
Fel Pro VS50312T, $50 from Kragen.
Be sure to use the load spreading washers in the correct places and torque the bolts to spec.
slmann
Missouri Chapter
18
Dec 6, 2006 07:38 AM
slmann
Missouri Chapter
17
Aug 11, 2006 08:54 AM
johnny8
20
Jul 15, 2005 08:49 PM
bruserdog
Mar 17, 2004 10:53 AM
