Crankcase Ventilation Rerouting
Old Feb 4, 2007 | 02:52 PM
  #91
buellsht's Avatar
buellsht
So is the ccv the cause of the oil dripping from the hot side cac tube connection at the intercooler? What keeps all of the oil from being sucked out ot the crankcase and the engine becoming a runaway?
Old Feb 20, 2007 | 06:46 PM
  #92
cabinetmaker00's Avatar
cabinetmaker00
I can't get these links for your pics to work keeps saying error retreiving pics
Old Feb 20, 2007 | 06:56 PM
  #93
cudajim's Avatar
cudajim
Yeah, Pics dont work for me either...maybe the pics were deleted?
Old Feb 20, 2007 | 08:01 PM
  #94
Danno126's Avatar
Danno126
I have to say, I don't agree with this mod. Giving up the vacuum effect to the crank case effectively gives up horsepower. It may leave a cleaner engine compartment or components, but think about this, no pressure build up in the bottom end means less oil leaks, better ring seal, and much less combustion contamination. Just my 2 cents....
Old Feb 20, 2007 | 09:06 PM
  #95
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Remember that the diesel has no intake vacuum in the system. The only vacuum you will get across the CCV tube is what little effect you get from the volume of air drawn by the tube...which is neglible.
Old Feb 21, 2007 | 09:44 AM
  #96
OZX1's Avatar
OZX1
To mod, or not to mod... That is the question!
So, my professional friends. Do I do this mod, or not? I'm hoping to get the TECHS opinions, but I'll respect anyones input.
Old Apr 21, 2007 | 11:31 AM
  #97
hd4ever's Avatar
hd4ever
So were are the photos? Did they take them off the site?
Old Aug 12, 2007 | 05:27 PM
  #98
LvTitan's Avatar
LvTitan
Originally Posted by pstrang
Darn...major bummer. I got the nipple and checkvalve installed. However, I decided to upgrade the exhaust in the process to a MBRP 3.5" turbo to CAT and then 4" from CAT back. I placed the nipple in the section between the CAT and the muffler. Welded in at 45 degrees as directed, but the dang thing blows exhaust out the nipple instead of sucking air in. I double checked...it's positioned the right way (according to the install instructions).
45 \ \
The exhaust blowing past the nipple should be sucking air in according to the Bournelli (sp?) principle. I tried having my wife rev the engine to blow more air past, it just blows exhaust out the nipple harder. I'm also pretty darn sure I installed the high flow muffler the right direction too.
BTW, I discovered this problem when I noticed oil forming around the check valve. I disassembed the hose and checkvalve and determined that the exhaust was a way higher pressure than the crankcase, so the oil leaked out of the check valve because it had no where else to go.
Any ideas anyone? I'm at a loss.
i know this is late, but i remember seeing 30degrees as the magic number, not 45
Old Oct 29, 2007 | 12:44 PM
  #99
KCGman's Avatar
KCGman
Pics not working....
Old Oct 29, 2007 | 01:00 PM
  #100
OZX1's Avatar
OZX1
Lightbulb
For a long time, now (search the thread) and they may never return in their original form...
Old Dec 1, 2007 | 04:32 PM
  #101
brian97cobra's Avatar
brian97cobra
the pix are no longer working....
Old Dec 1, 2007 | 07:33 PM
  #102
OZX1's Avatar
OZX1
Lightbulb
Um... Yeah! See post #100
Old Dec 1, 2007 | 10:53 PM
  #103
thedaddycat's Avatar
thedaddycat
I realize this site shows the CCV reroute mod(with pics) on a 7.3, still some good information that can be used on the 6.0 though along with a lot of other stuff...
http://guzzle.rbmicro.com/index.html
Old Dec 2, 2007 | 08:14 AM
  #104
brian97cobra
the more important question here is why are they gone and can they be gotten back?
Old Dec 2, 2007 | 11:35 AM
  #105
OZX1's Avatar
OZX1
You would know the answer if you had read the thread... See post #89.
