Warranty plate decoding
Old Sep 7, 2004 | 12:49 PM
dnrast's Avatar
dnrast
I have looked just about everywhere to get infoto decode my warranty plate and have come up empty. I have checked the archives but the only thing I came across was a comment to check the stickys. I dont know where to find the stickys in the archives. Looking to decode from a 1977 F250 club cab Explorer Vin: X25JKO64054, WB: 155, Color: P, Type/GVW: X259, Body: NUM, Trans: G, Axle: 37E 1977 53 Thanks
Old Sep 7, 2004 | 01:03 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check the Read First: thread at the top of this forum.
Nobody knew what "sticky" meant so we changed the system code to read Read First:
Old Sep 7, 2004 | 02:06 PM
dnrast's Avatar
dnrast
Mil1ion has a link that looks like it would do the job but the page doesn't load all the way.
Old Sep 7, 2004 | 05:21 PM
f250rangerexplorer's Avatar
f250rangerexplorer
http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi go here it says that you truck is a 1972????? 2 wheel drive "460ci". i know that the trans code is the same as mine. G is a "c-6". built in "Kansas City". color code P is "dark nectarine poly". what is the axel code? 37E doesn't seem right. Hope this helps.
1978 F-250 Ranger Explorer 4x4
351M, C-6, Np205, D44, D60 4.10LS
Drive It Like You Stole It!!!!!
Old Sep 7, 2004 | 06:50 PM
fatherdoug's Avatar
fatherdoug
37 is a Dana 60 5300 lb axle with a 3.54:1 ratio. The "E" designates a 3550 lb Dana-44 front axle with power steering. Does it have a tilt column, also?
Old Sep 7, 2004 | 09:33 PM
dnrast's Avatar
dnrast
I think someone replaced the column with a later model straight column as the column dash cover is the type you would find on the 80-86 model. I really was trying to find out what the Type/GVW code of X259 and Body: NUM codes meant. I know that the VIn Identification from Michael Masse at medicine.wisc.edu lists this as a 1972 but it is definately a 1977 Supercab Explorer 4x2 F250. Thanks for the help.
Old Sep 7, 2004 | 09:54 PM
fatherdoug's Avatar
fatherdoug
X259 designates the truck as a supercab F-250 2WD with a GVW of 8100 lbs. The body designation should be two letters, followed by a number.
Old Sep 7, 2004 | 10:46 PM
Mil1ion's Avatar
Mil1ion
X25= F250 Super Cab (Club Cab is Dodge)
J = Engine = 460
K = Plant built at = Kansas City
O64054 = Consecutive build number
WB: 155 = Wheelbase = 155"
Color: P = Dark Nectarine Poly (?)
Type/GVW: X259= As in the post above
Body:
N = Material & Seat type Code =No Info available (Re-check this)
U = Trim Colour Code = Tan
M = Body Type = Super cab Styleside Pick-up
Trans: G = Automatic =C6
Axle: 37 = Dana 60 3.54:1
E = Tilt Column with Power steering
1977
53 = DSO =Sent to Kansas City
Thanks
Old Sep 8, 2004 | 02:37 AM
f250rangerexplorer
hey mil1ion where did you find all this info. is there a guide book or sowtware or what?
Old Sep 8, 2004 | 10:00 AM
dnrast's Avatar
dnrast
Thumbs up
Thanks for everyones help and yes I was incorrect with my terminology it is a supercab.
Old Nov 24, 2004 | 09:44 PM
TallGuy_Az's Avatar
TallGuy_Az
Alright - I'm thinking this set of doors didn't come with the '79 truck. Can someone help me out?
X255K062094
WB - 155
COLOR - V
TYPE/GVW - X255
BODY - BBM
TRANS - A
AXLE - 24J
MAX GVWR - 06550
DSO - 1977 731155
Any decoding help would be appreciated.
I decoded the vin from the cab - which says it is a 79.
F14HRFE5223 23-113
bgiesler
Jan 16, 2017 06:18 PM
Pacecar1986
Jan 2, 2017 05:56 PM
Ripemdry
20
Jan 24, 2016 06:40 PM
Pacecar1986
Jul 17, 2014 08:18 PM
duallyhauler
Jan 5, 2013 11:36 PM
