Question about decoding the vin
Old Jan 23, 2016 | 03:43 PM
Ripemdry's Avatar
Ripemdry
I have been to the site posted around the forum here to decode the vin but I still have a few questions. According to my title i have a 1976 f250, The vin on the warranty sticker is telling me it is a 1977... I think. Also I do not have the plate that they show in the picture as the example. I only have a white sticker. It does not have half the info that that plate would show.I guess my question is what year is my truck really and what motor was supposed to be in it?
Old Jan 23, 2016 | 03:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Warranty Plate (upper pic) riveted to the left door face below the latch.
If it's missing, a replacement with the VIN & all the correct codes stamped on it is available from martiauto.com by passing along your VIN and some bucks.
Safety Standard Certification Label (lower pic) glued to the B pillar below the striker plate. Has the production date (upper left corner), VIN and misc GVW's printed on it.
Old Jan 23, 2016 | 04:03 PM
dads1977's Avatar
dads1977
you can try this link
VIN Decoder - Ford Truck Enthusiasts Forums
or I used this
Decoding '73-'79 Ford Truck VIN Tags - FORDification.net
Old Jan 23, 2016 | 05:36 PM
Ripemdry's Avatar
Ripemdry
Part of my problem with some of those sites are I do not have a 17# vin it's only 11. martiauto.com is asking me for the year of the truck and that is one of the things I'm not sure about. I'm not 100% sure of the motor either. The hood has a decal that says 351 but the motor has a sticker on the valve cover that says 400. I was told the truck had a restoration about 13 years ago so I no longer know whats original and what is not. It has been through 2 other owners since then.
Old Jan 23, 2016 | 05:54 PM
march's Avatar
march
The second link works to decode your 11 character vin.
Does the safety cert sticker match the vin on the title?
It is possible that the cab is not original. I'll also note that 351/400 was not available until 77.
The true vin for your truck is stamped on the top of the passenger side frame in two locations. One in the engine bay and the other under the cab.
Here is mine...
They can be supper hard to find after 40 years, but it's there.
Old Jan 23, 2016 | 06:21 PM
Ripemdry's Avatar
Ripemdry
As soon as I can get the truck back into the garage I will try checking those spots. I tried the vin on that second site and it says it's a 77 but dmv has the title as a 76. I don't really care other than the fact I do not want to order parts that don't or won't work. The sticker says it was manufactured 8/76 maybe it is supposed to be titled as a 77 but dmv saw that and thinks it's a 76? the last numbers of the vin put it in the 77 model year. Then again it is the door tag not the stamped vin so I guess I really need to look at those first. I just wish I wasn't in the middle of a blizzard.
Old Jan 23, 2016 | 06:30 PM
Steven@nd's Avatar
Steven@nd
Depending on which state it was first titled in, the title goes by the year it was first registered rather than the model year of the vehicle.
To determine which engine go here:
http://www.fordification.com/tech/engineID-V8.htm
Old Jan 23, 2016 | 11:05 PM
Ripemdry's Avatar
Ripemdry
That is a good point I did buy it out of state.
Old Jan 24, 2016 | 07:20 AM
hoss73ford's Avatar
hoss73ford
August 1976 was about the time of model year changeover so that is kind of a gray area. Might have sat on a dealer lot quite a while before it was bought newe and titled and thus titled a 1976 or 1977.
Old Jan 24, 2016 | 07:23 AM
hoss73ford's Avatar
hoss73ford
One sure fire way to tell is the front emblems. 1973-76 used the same F250 emblems and were mounted on the front fenders. 1977-79s were mounted near the doors and were redesigned.
Old Jan 24, 2016 | 09:19 AM
NumberDummy
Post the VIN, one of us can decode it for you. 8/76 production could be a 1976 or 1977.
Old Jan 24, 2016 | 12:37 PM
GLR's Avatar
GLR
If the NY DMV says it's 1976, it's a 1976. They are always right !!!!
Once I was looking for some parts for sons' 91 Merc, junkyard had one. Turned out to be a 92 style, made in April 1991 according to the date on the warranty sticker.
Is the VIN on the warranty sticker the same as the title?
Old Jan 24, 2016 | 02:59 PM
Ripemdry's Avatar
Ripemdry
Yes they are the same. Here is the vin if someone can decode it for me. F25s4002175
Old Jan 24, 2016 | 03:05 PM
NumberDummy
Yes they are the same. Here is the vin if someone can decode it for me. F25S4O02175
F25 = F250 2WD
S = 400 2V
4 = No such assembly plant code, it has to be a letter.
O02175 = 1977.
Old Jan 24, 2016 | 03:29 PM
GLR's Avatar
GLR
A low number 77. Nice. But keep that info to yourself. No sense letting the DMV know.
