Aerostar Ford Aerostar
Running RICH! Code 173
Old Mar 20, 2002 | 07:41 PM
wildjon300ci's Avatar
wildjon300ci
My Mom's 1992 4.0 V-6 aerostar is running RICH! You can see it comeing from the tailpipe at idle, cruise, and WOT it's like a diesel with the injection pump turned ALL the way up. We've replace the thermostat (was stuck wide open not allowing the engine to warm up and thus making the computer think the engine is cold and run rich) and we replaced the coolant temp sensors. We replaced the fan due to the original one literally falling apart. The injectors have had cleaner run through them and it has new spark plugs. The spark-plug wires are about to be replaced next. Where's the spout connector on this thing? I wanna check the timing. Does this engine have a distrubitor? This stupid electronic crap hs me stumped.
Old Mar 21, 2002 | 08:52 AM
Mikeman's Avatar
Mikeman
First on the list of suspects would be a failed fuel pressure regulator since this thing is rich all the time at all conditions. Hook up a fuel pressure gage to the fuel rail to check it (easier said than done, it's crowded in there). It should be around 40 psi. While you're at it, you might as well clean the MAF sensor. There is no distributor nor any way to change the timing. There is a coil pack that is controlled by the ignition control module.
Old Mar 21, 2002 | 03:13 PM
aerocolorado's Avatar
aerocolorado
Magnum199944
Mar 9, 2014 07:02 PM
roller_steve
13
Dec 2, 2006 07:07 AM
mike L
Mar 4, 2006 06:13 PM
wildjon300ci
Mar 24, 2002 06:46 PM
