460 will not fire
Old Sep 6, 2004 | 10:10 PM
diesel460's Avatar
diesel460
460 will not fire
My 460 will not fire at all. Prior to this it would crank over for a really long time before starting. Any suggestions what this might be.
Old Sep 7, 2004 | 03:27 AM
351M's Avatar
351M
just a guess but fuel pump(s) mabey?
Old Sep 7, 2004 | 07:16 AM
diesel460's Avatar
diesel460
Question it's receiving lots of fuel
coil seems to get hot and ignittion module on fire wall
Old Sep 7, 2004 | 07:17 AM
sdetweil's Avatar
sdetweil
EFI? Check the fuel pressure. Could be pump and pressure regulator
Sam
Old Sep 7, 2004 | 08:19 AM
holland501's Avatar
holland501
You didn't say anything about the condition of the engine. Since you mentioned that it used take a lot of cranking b4 it would start in the past, I'm thinking it's got high miles. This is a common problem with worn timing chain/gears. Good luck.
Old Sep 7, 2004 | 10:59 AM
351M's Avatar
351M
it could possibly be the modual or coil, try putting the coil wire near a good ground and plug and unplug the modual to see if the coil sparks. I actually have no idea if this will work but I know that on my 70's and 80's vehicles if you do that the coil will spark.
Old Sep 7, 2004 | 11:55 AM
diesel460's Avatar
diesel460
will not fire
It is carburated And no the miles are not high the cranking over for a long time was in the past week
Old Sep 7, 2004 | 12:27 PM
HAMMER DOWN's Avatar
HAMMER DOWN
if you prime the carb and it runs for a moments then shouts off t is probly not getting fuel take off your fuel line at the carb and place a cup to catch the gas and crank it a few times it is a good way to see if your getting fuel if your not getting fuel try replacing the filter start with the ceapest thing and work you way up then if you still no geting fule the pump may be bad pull the pump and placeyour finger over the inlet side and pump it by hand see if your getting any suction it
also is it poits are electronic
points might be shot
Old Sep 7, 2004 | 01:59 PM
351M's Avatar
351M
Here is the big question I keep forgeting to ask, what year is it?
Old Sep 8, 2004 | 08:17 PM
diesel460's Avatar
diesel460
year?
1976 model 460. I thnik I'm burning the coils up I have direct power to it without a ballaster.
Kyle Hager
Mar 6, 2019 09:51 AM
AgentOrange
Jan 19, 2004 12:09 PM
carpe_diem
Aug 1, 2003 09:22 AM
idunno
May 11, 2003 08:28 PM
lephant
Feb 25, 2002 11:27 PM
