1978 - 1996 Big Bronco
burn out question
Old Sep 6, 2004 | 09:27 PM
COBRAjrb's Avatar
COBRAjrb
burn out question
hey i was wondering why broncos cant burn out very well? well atleast mine doesnt well i have 33's and stock gearing would that be a problem ? i know there extremly heavy rigs, could it be a lack of power? what do u guys think?
Old Sep 6, 2004 | 09:47 PM
Breeze's Avatar
Breeze
Even my 460 79 Bronc doesnt like to do a burnout... one of the main culprits being the short wheelbase combined with the weight. When you stomp on it, they transfer alot of weight to the rear end. Combine that with big tires and stock 3.50 gearing, and the end result is broken parts and no burn outs
Old Sep 6, 2004 | 10:17 PM
ANdrewdrice's Avatar
ANdrewdrice
yep, thats about the half of it. they are made to drive on uneven surfaces and haul heavy things, they werent made to burn out. simple fact. plus on top of that, your tires are WAY too heavy for your engine to turn fast enough to slip on the pavement. your gearing is already making the engine lose power with the increased tire size. on top of all that, tires are way too expensive to waste doing burn outs.
Old Sep 6, 2004 | 10:30 PM
greystreak92's Avatar
greystreak92
Ditto to what has been said. And to add something I once read about the top speed of the Rolls Royce Corniche, "Not the kind of thing one cares about from one of these machines" Why go fast when you can just go over?
Old Sep 7, 2004 | 01:10 AM
COBRAjrb's Avatar
COBRAjrb
maybe its time to get better gearing like 4.10, o and yea about 300 more hp lol.
Old Sep 7, 2004 | 12:46 PM
Kemicalburns's Avatar
Kemicalburns
Hope you have about $5grand cuz thats what it will cost to do what your asking. if you want to burn out get a car thats built for such abuse.
Old Sep 7, 2004 | 02:31 PM
90ebbronc's Avatar
90ebbronc
Mine can do a burn out, lol. 31s and a 302. It takes it awhile for the mud kings to start smoking, but itll do it. Ive done it once just to see if it would, it did, i smiled and have never done it again, lol. But in a way, its a good thing that it doesnt spend cause i can beat alot of ppl off the line that way.
Old Sep 7, 2004 | 02:53 PM
bronson85's Avatar
bronson85
i burned out when i first got my truck, but the tires were balled over 31's.
how does the short wheelbase stop it from burning out
Old Sep 7, 2004 | 09:04 PM
NascarNut's Avatar
NascarNut
More weight is transfered to the rear tires. Our ext. cab long bed F150 will spin the tires pretty easily.
Someone correct me on this if I'm wrong but back in the 60s tire technology wasn't to great. The NHRA boys figured out that moving the rear tires forward would give them more grip but it also made the cars look funny. And that's where the phrase "funny car" comes from. I believe it was first done on Mopars and then everyone else followed.
Old Sep 7, 2004 | 09:45 PM
aurgathor's Avatar
aurgathor
As it was already said, the best to use a car/truck that has a light rear end like long bed trucks. Barring that, you can install very small tires (i.e. LT215/75R15), or put some grease or oil on your rear tires. If you do the latter, make sure you burn it off, or clean it off before use it for regular driving.
Old Sep 7, 2004 | 10:03 PM
bossind's Avatar
bossind
Burn outs?? Burn outs are for kids! Big *** bronco have no right doing burn outs, and mustangs have no place off road.
Old Sep 7, 2004 | 10:18 PM
MinnManBroncoFan's Avatar
MinnManBroncoFan
NascarNut
Ah the AFX days make mine a t-bolt or a early falcon
Doing a burn out is EZ leave your truck in netural wind the motor up to 4,000 to 6,000 then just drop it into gear
or put the truck into reverse and stomp it then slide it into drive
just keep into mind that your gonna break somthing
Old Sep 7, 2004 | 10:56 PM
broncobillybob's Avatar
broncobillybob
I find burn outs unattainable in my Bronco, to counter this I "peel out" so to speak. Best results are obtained when pebbles or loose gravel is present on the pavement to start the pleasure of burning rubber. Or turn your front wheels and stomp it.
Old Sep 7, 2004 | 11:39 PM
COBRAjrb's Avatar
COBRAjrb
90ebbronc, is your bronco stock? i guees that makes since because of the short wheel base. does any body no where i can buy 410 gears, and how much they cost?
Old Sep 7, 2004 | 11:50 PM
94Bronco58's Avatar
94Bronco58
I got the cab of my Bronco filled with smoke from my 31's, was a wet morning in my school parking lot........ saw it as a perfect oppurtunity!!
