Aerostar Ford Aerostar
engine noise
Old Apr 7, 2002 | 07:52 PM
dougas's Avatar
dougas
engine noise
My van is ticking at a cold idle. When it warms up it goes away. Every once in a while it ticks when it is warm. Any suggestions? 1990 4.0L Aerostar
Old Apr 8, 2002 | 05:20 PM
aerocolorado's Avatar
aerocolorado
engine noise
Common problem with 4.0l engines, no attention required.
Old Apr 8, 2002 | 10:12 PM
rickm5's Avatar
rickm5
engine noise
i've got the same problem. my aerostar is a 91 with 150 thou plus miles on it. a check of the archives shows it is a common complaint as aerocolorado said. guess its related to wear on the top end, lifters,rocker arms etc. i was going to ask if a valve adjustment would help,as i will be replacing the valve cover gaskets this spring, one guy said think of it as getting a few more miles per gallon,since everything is so well broken in...? just annoying. happy ford motoring rick p.s. by the way, how many miles on your engine and tranny?
Old Apr 9, 2002 | 09:26 PM
dougas's Avatar
dougas
engine noise
1990 4.0 290000k on van but there is a new motor in it. 3 transmissions. i just bought the tranny dont know the km on the tran. i had lots of problems with the van that ticking noise is driving me bonkers .i have to change the head gasket soon you can see where the antifreeze is seeping through i will check it out then if you have any other problems reply maybe i can help
Old Apr 10, 2002 | 09:05 PM
dougas's Avatar
dougas
engine noise
